I’ve set up a connection with S3 for backups in Wordpress Remote backup option in Cyberpanel.
Unfortunately, then when I try to add a Website to the Backup I get:
Cyberpanel: 2.3.5
LiteSpeed Enterprise
Ubuntu 22.04
Cyberpanel: 2.3.5
Ubuntu 22.04
Let me check
I am able to add the WP site, can you turn on debug logs and tail the log file when you add the WP site to the schedule.
See this for logs: Log files on CyberPanel
Hello @usmannasir,
sudo -u trapi3089 /usr/local/lsws/lsphp81/bin/php -d error_reporting=0 /usr/bin/wp config get DB_NAME --skip-plugins --skip-themes --path=/home/trapi.cl/public_html/
[05.08.2024_02-15-29] yiYHS/4G7WbDy4lADkJv5yfnPAgiGAX4sudo -u trapi3089 /usr/local/lsws/lsphp81/bin/php -d error_reporting=0 /usr/bin/wp config get DB_NAME --skip-plugins --skip-themes --path=/home/trapi.cl/public_html/
This is what I get in the Logs.
It seems like /usr/bin/wp does not exist.
These sites were imported from another Cyberpanel with the importation tool.
@usmannasir
Hello @usmannasir .
This is a new VPS with sites imported from another Cyberpanel with the importation tool ( REMOTE BACKUPS).
Do you find anything strange in the previous Logs?
Best regards!
I run twice this code and make Wp cli work at least:
But there are no error logs appearing when using touch /usr/local/CyberCP/debug, just the 2 ines of code provided previously.
