Wordpress + LSCache installer error with base during installation
I tested a WordPress installation from Cyberpanel today.
I get an error during automatic installation:
Installation failed. Error message: ["Error: Database connection error (1130) Host '::1' is not allowed to connect to this MariaDB server"," [404]"]
If I go and create the database manually, then install Wordpress manually, the site works fine.
This installer doesn’t seem to be working properly?
Info:
  • AlmaLinux8
  • Current Version: 2.3 Build: 7
In the meantime, I tried the following:
  • I reinstalled the server and installed Ubuntu 22.04 instead of AlmaLinux8
I tested the WordPress installation in two ways:
  1. WordPress - Deploy WordPress
  2. Websites - list websites - Manage - Application Installer - WP+LSCache
In both cases I get the identical error:
Installation failed. Error message: ["Error: Database connection error (2002) php_network_getaddresses: getaddrinfo failed: Name or service not known"," [404]"]
I tried installing php-mysql but that doesn’t help.
Restarting the server does not help.
Disabling Modsecurity does not help.
Turning off the CSF does not help.
Does anyone know of a solution that can help?
Got the same problem!
