hey how create this type wildcard subdomain create like *.example.com.
You can’t
I bought MultiSaas script from Codecanyon and the author even says in the sale page to not install Cyperpanel since their script requires Wildcard Subdomains and SSL. This is the link:
I hope Usman and his team have a plan to integrate Let’s Encrypt WIldcard SSL. Cyberpanel needs this feature IMO
Hello, there its easy to create wildcard in cyberpanel
- on dns records create a records with *
2.on ssh root terminal create a user for openlitlespeed. comand 1. sudo /usr/local/lsws/admin/misc/admpass.sh
connect to litlesped yourip:7080
3.on listerns add your domain with this in front *.yourdomain.com
4.on https://punchsalad.com/ssl-certificate-generator/. you can create ssl wildcard for free for 90 days.
very important to graceful restart litlesped after changes
im using wildcard with out any issues, also i run a ssas server
Refer to: on dns records create a records with *
Can I know how to setup this dns record since I am not sure how to do it?
Thanks and regards.
Updated: Please ignore this question since I think I have figured it out, not sure if it is working or not, until further testing.
