Few days ago, the hostname sub.domain.com:8090 with SSL was working. But suddenly today, i cant access with https://sub.domain.com:8090/, luckily the http is working.
I click ssl hostname to issue cert many times, without any error. but it wont let me use the https: only HTTP
My domain hosted with cloudflare, and its using dns only.(was working and did not make any change)
i clear my cache and dns cache, also the same. i didnt change any hostname
do you have a fix?
I’m suddenly having this issue. I had it working with Cloudflare proxy and panel.domain.com:8090, then suddenly it stopped working… Can’t figure it out
Update: Perhaps I didn’t have proxy enabled previously for the panel. subdomain. I was messing proxies and probably enabled it accidentally. I just disabled it for panel. and it works again.
