WHMCS module
I am running the latest 1.8.7, with API on and latest WHMCS.
I installed the WHMCS module configured packages etc.
I tried to add an account and received this error:
Order Accept Encountered Problems
In the WHMCS modules log it shows
request: modules/servers/cyberpanel/api.php
response: sds
In WHMCS servers section if I click the button “Log into Control Panel” if does log me in.
When i use the Test connection, the results are: fail
Nothing is shown in the CyberPanel logs.
Does the WHMCS module work or is it still in development?
Any help would be greatly appreciated.
If this is not a production server, would it be possible to provide access to the WHMCS installation?
response: sds
Will release an update for module to include some logging soon as well.
The WHMCS is production as is the server it is on
The server CyberPanel is on is not a production server.
Can you PM me your CyberPanel login details? I’ll try to reproduce on my end.
Salam n Hola…
I have the same problem. Seeing the same error in Module Logs as well.
CyberPanel 1.8.7
WHMCS 7.7.1
Hi, I’d love to have a WHMCS module as well. I don’t care so much for automated account management. I just need the 1-click server login function from the WHMCS servers page.
Is this function being added?
Hi, I hope that you found a solution. Because we are having the same problem. Please let us know if it has been solved in that case we can apply the solution too. Regards
Hi, I’m having the same problem. Its strange tho since API doesnt allow to create any user how does it suppose to even work ? @CyberPanel @usmannasir Please help us in here its really holding us back from scaling up our Cyberpanel game. Thanks!
same problem, even test connection button on the server configuration doesn’t do anything
I can’t create an account with the whmcs module
Please help me,
Thank you
