since I can’t install discourse… What is another forum which I can run without any issue…
Use this guide to install Discourse → How to install NextCloud on CyberPanel with Docker - CyberPanel
The process is 90% same apart from that any other PHP based forum should work like Vanilla etc.
@usmannasir said:
Use this guide to install Discourse → How to install NextCloud on CyberPanel with Docker - CyberPanelThe process is 90% same apart from that any other PHP based forum should work like Vanilla etc.
nextcloud??
Type your comment> @h1dd3n_sn1p3r said:
Try: https://flarum.org/
+1 for Flarum, it’s a great piece of software with an amazing community behind it, and just entered stable with the last release, so no extension breaking changes for a while.
Thats great…I am thinking about it…because discourse is getting hard to install
I am getting 503 service unavalible error
Flarum is simple to install but you do need to use the command line (there is no GUI), but it’s a 5 minute task.
If you decide to try it out and need any help just shout.
Actually, I tried to install with the command but unable to install it…will you please help…command successfully run but on exactly which folder will it be public html or a new empty one I am so confused
your help will be really apperciated
