The server only has three web .
However, there is something that is pulling resources very strongly, the CPU alone. I checked the log errors, there is nothing.
How do I check this?
Do you have problem from yesterday? I cant access to my cyberpanel from yesterday. I have there 6 websites.
Yes, it is true. I think there is a problem with the board or with the company vps
what
Good luck for u.
Hello dear, it seems as you explained indeed.
Did you fix this and how? I have also this problem.
You have to cleanup your server, the attack generates files, processes, users, it really depends on what happened on your server, there are some cleaners available to help you do this in case you don’t know how, I created this one since I had multiple servers affected I created it to automate the cleanup process: GitHub - elwizard33/Cyberpanel-Server-Wizard-Cleanup: These scripts are designed to help identify and clean potential malware and ransomware infections on CyberPanel servers
