I’m preparing an option to upgrade with each new version of CP while maintaining the entire default base.
Soon I’ll finish, then I’ll share it for you to analyze.
I’m thinking of a more advanced updater by sh instead of just inserting css into the panel. This is easy to do, but needs to be stable and maintain cyberpanel default brand. =)
For my personal use I will change html too, but to share, it will be just css, this will avoid any problem or incompatibility.
But I noticed that the css of the page “Design” has no effect on all areas of Cyberpanel, so they will be updated directly via sh.
This allows in the future, you add a theme selector in addition to the common css page (/base/design), as it currently works. I will plan the best option and then share here for analysis. For now I’m just playing with styles for personal use. =)
If you could make the css of the customization page have an effect on all areas of Cyberpanel, this would solve a full customization. Can you do that for the next update?
Hi, this theme is not conventional, it is more advanced and it is not ready yet, as soon as it is finished, it will be sent to the usmannasir to analyze and we will see the best way to make it available.
The idea consists of an option to enable more advanced themes. It will still be evaluated.
I’m happy to contribute, i will soon make more themes, I have another in mind that is the opposite of dark and will be well accepted. Little by little, not to get too many.
