Fresh install Centos 8
Fresh install Cyberpanel Ent
Add website, selected SSL, and…
NET::ERR_CERT_AUTHORITY_INVALID
Subject: www.example.com
Issuer: www.example.com
Expires on: 4 lis 2022
Current date: 7 sie 2020
why I have exaple.com in the certificate and not my domain?
can you chceck my DNS on domain zasilam.pl ?
I think there is still something wrong because SSL is not generating.
I buy new domain, an i set A record to IP 51.83.186.227
I install prestashop with autoinstaller, but i cant acces to page
ERR_EMPTY_RESPONSE
Ok guys. When i install OpenLiteSpeed Enterprise - not work
When install Opelnitespeed Free all works
something is wrong with the enterprise version
You need to purchase a license to install the Enterprise version or you can sign up for a free trial after you install the (free) Openlitespeed version if you go to server status → litespeed status in your panel.
I have a license.
When I put it in during installation it is an SSL problem.
However, when I install the free version and enter the key after setting SSL, there is no problem.
