Websites Extremely Slow After Updating to CyberPanel v2.4.4
Hello
I recently updated my server to CyberPanel v2.4.4 (Latest Commit: 0086996150c1743807682dd0ac4bdbd090fd6c21).
Since the update, all of my websites have become extremely slow to load. I have:
  • Reviewed almost all server and PHP settings.
  • Cleared all cache and LSCache memory.
  • Restarted all services (LSWS, PHP, etc.).
Unfortunately, none of these actions improved the situation. The websites are still very slow, even simple pages take much longer to load than before the update.
Has anyone else experienced similar performance issues after updating to v2.4.4? Are there any recommended fixes, configuration changes, or known bugs that might cause this?
Any guidance or suggestions would be greatly appreciated.
Thank you in advance!
If you are using WordPress.
  1. Go to the crawler settings in the LiteSpeed Cahe plugin.
  2. Set Server Load Limit to something reasonable withing the higher end of your load if you can allow it.
  3. Check your Blocklist, This is where I get a lot of problems. The blocklist is usually high with a lot of urls that I did not specify. hence it blocks caching.
  4. Empty the blocklist.
  5. Go to Summary and Manually Scan.
This will properly cache your site again and make it run properly.
