Website not returning correct 404 500 403 status code instead 302
hey
my install version:
My website files are just some html and php files.
When accessing a non-existing directory or file, the server returns a 302 code instead of a 404 status code:
Accessing the existing directory, that is, 403 will redirect infinitely to 404.html
Due to user restrictions, I have merged all images:
my .htaccess fiel:
Rewrite Rules Added by CyberPanel Rewrite Rule Generator
RewriteEngine On
RewriteCond %{HTTPS} !=on
RewriteRule ^/?(.*) https://%{SERVER_NAME}/$1 [R,L]
End CyberPanel Generated Rules.
RewriteEngine On
RewriteCond %{HTTP_HOST} ^www.(.)$
RewriteRule ^(.
)$ http://%1/$1 [L,R=301]
But my other websites, wp, laravel, etc. are all normal and can return the error status code normally!!!
For security reasons very first thing update your cyberpanel.
Then delete .htacces, go to wp-admin set site domain https://www or non www after that go permalinks and press save then start adding rules .htacces
I upgraded the version and it didn’t seem to fix the problem
