Today I installed immunify360 on my server, but can’t enable it. The checkbox is disabled. Does anyone have any idea to enable it?
what is the status from the terminal?
@shoaibkk Any update on this? i too have this issue.
Somehow I fixed it.
How did you fixed it?
I managed to fix this issue but just by configuring WebShield SSL Cache manually and adding my certificates.
@nawaze does your WebShield SSL Cache now intergrate with cyberpanel automatically, or did you have to configure SSL certificates manually?
@iamstevenelson hope you might have found another fix that intergrates with CyberPanel!
Same! i have fixed it by adding certificates manually!
How do I manually add certificates in CyberPanel to configure Imunify360 WebShield properly?
