I wanted to update because SSL does not work and I installed python 3.7, but I think the cyberpanel crashed gives errors and does not open the site.
File “upgrade.py”, line 2109, in
main()
File “upgrade.py”, line 2105, in main
Upgrade.upgrade()
File “upgrade.py”, line 2020, in upgrade
File “/usr/local/CyberPanel/lib/python2.7/site-packages/django/db/models/manager.py”, line 85, in manager_method
File “/usr/local/CyberPanel/lib/python2.7/site-packages/django/db/models/query.py”, line 373, in get
num = len(clone)
File “/usr/local/CyberPanel/lib/python2.7/site-packages/django/db/models/query.py”, line 232, in len
self._fetch_all()
File “/usr/local/CyberPanel/lib/python2.7/site-packages/django/db/models/query.py”, line 1102, in _fetch_all
File “/usr/local/CyberPanel/lib/python2.7/site-packages/django/db/models/query.py”, line 53, in iter
File “/usr/local/CyberPanel/lib/python2.7/site-packages/django/db/models/sql/compiler.py”, line 863, in execute_sql
sql, params = self.as_sql()
File “/usr/local/CyberPanel/lib/python2.7/site-packages/django/db/models/sql/compiler.py”, line 420, in as_sql
File “/usr/local/CyberPanel/lib/python2.7/site-packages/django/db/models/sql/compiler.py”, line 373, in compile
File “/usr/local/CyberPanel/lib/python2.7/site-packages/django/db/models/sql/where.py”, line 79, in as_sql
File “/usr/local/CyberPanel/lib/python2.7/site-packages/django/db/models/lookups.py”, line 169, in as_sql
File “/usr/local/CyberPanel/lib/python2.7/site-packages/django/db/models/lookups.py”, line 162, in process_lhs
File “/usr/local/CyberPanel/lib/python2.7/site-packages/django/db/models/fields/init.py”, line 640, in db_type
File “/usr/local/CyberPanel/lib/python2.7/site-packages/django/utils/functional.py”, line 35, in get
File “/usr/local/CyberPanel/lib/python2.7/site-packages/django/db/backends/mysql/base.py”, line 174, in data_types
File “/usr/local/CyberPanel/lib/python2.7/site-packages/django/db/backends/mysql/features.py”, line 53, in supports_microsecond_precision
File “/usr/local/CyberPanel/lib/python2.7/site-packages/django/db/backends/mysql/base.py”, line 385, in mysql_version
File “/usr/lib64/python2.7/contextlib.py”, line 17, in enter
return self.gen.next()
File “/usr/local/CyberPanel/lib/python2.7/site-packages/django/db/backends/base/base.py”, line 591, in temporary_connection
cursor = self.cursor()
File “/usr/local/CyberPanel/lib/python2.7/site-packages/django/db/backends/base/base.py”, line 254, in cursor
return self._cursor()
File “/usr/local/CyberPanel/lib/python2.7/site-packages/django/db/backends/base/base.py”, line 229, in _cursor
self.ensure_connection()
File “/usr/local/CyberPanel/lib/python2.7/site-packages/django/db/backends/base/base.py”, line 213, in ensure_connection
self.connect()
File “/usr/local/CyberPanel/lib/python2.7/site-packages/django/db/utils.py”, line 94, in exit
self.connect()
File “/usr/local/CyberPanel/lib/python2.7/site-packages/django/db/backends/base/base.py”, line 189, in connect
File “/usr/local/CyberPanel/lib/python2.7/site-packages/django/db/backends/mysql/base.py”, line 274, in get_new_connection
File “/usr/lib64/python2.7/site-packages/MySQLdb/init.py”, line 81, in Connect
File “/usr/lib64/python2.7/site-packages/MySQLdb/connections.py”, line 193, in init
super(Connection, self).init(*args, **kwargs2)
django.db.utils.OperationalError: (2002, ‘Can\‘t connect to local MySQL server through socket \’/var/lib/mysql/mysql.sock\’ (2 “No such file or directory”)’
