hi
any one face such issue
firewall is blocking me to access website / control panel , even not able to add records , i Nees to stop with " systemctl stop firewalld" .
I do update cyperpanel but sill same issue ! any idea
here are the commands, add port manually to solve this issue
firewall-cmd --add-service=ftp
firewall-cmd --add-service=http
firewall-cmd --add-service=https
firewall-cmd --zone=public --add-port=8090/tcp
[09-04-40-Fri-May-2018] #########################################################################
[09-04-40-Fri-May-2018] FirewallD successfully enabled on system startup!
FirewallD is not running
what I guess is because of bug with ver 1.6.4 or need to run without yum update , the previous one was working fine
There is something wrong with Centos 7.5, firewalld does not start. Or even in Centos 7.3 after yum update.
hi;
I am sure somehow it is cyberpanel bugs,
it is saving when adding a new rule , bt not updating old rules so you need add them manually.
you have two choice -
first stop firewall form ssh
1- delete rules one by one and add them manually
[ OR ]
2- replace attached public.xml file located in >> /etc/firewalld/zones
reboot
hi;I am sure somehow it is cyberpanel bugs,
[ OR ]
2- replace attached public.xml file located in >> /etc/firewalld/zonesreboot
You are testing firewalld on plain or CyberPanel server?
on CyberPanel server
I am having this situation. However, it depends on the VPS installed. Some VPS has such a firewall error, others don’t
Just ran into this myself. FTP was the only thing enabled. Everything else had to be enabled. After the reboot, I got kicked out of everything, including SSH. Fortunately, I was able to use the console connection my host has to get around that and enable HTTP, HTTPS, and add the needed ports. Props to @khamiss for adding the commands to manually fix the problem.
