web error log [moddecompress+++] compressbuf in 0, inflate/deflate return -5
Wordpress 4.9.1
LSP 1.6.5
2017-12-01 10:13:13.088 [ERROR] [178.154.171.75:45388] [moddecompress+++] compressbuf in 0, inflate/deflate return -5
2017-12-01 11:00:10.815 [ERROR] [112.225.62.32:50873:HTTP2-1] [Module-Cache] createEntry failed.
2017-12-01 11:01:06.566 [ERROR] [112.225.62.32:50873:HTTP2-9] [Module-Cache] createEntry failed.
2017-12-01 17:26:30.781 [ERROR] [203.208.60.164:43119] [moddecompress+++] compressbuf in 0, inflate/deflate return -5
2017-12-01 17:30:36.452 [ERROR] [203.208.60.167:36915] [moddecompress+++] compressbuf in 0, inflate/deflate return -5
2017-12-01 17:50:20.127 [ERROR] [37.115.190.154:62170] [moddecompress+++] compressbuf in 0, inflate/deflate return -5
2017-12-01 17:50:20.128 [ERROR] [37.115.190.154:62170] [moddecompress+++] compressbuf in 0, inflate/deflate return -5
2017-12-01 17:50:21.101 [ERROR] [37.115.190.154:60781] [moddecompress+++] compressbuf in 0, inflate/deflate return -5
2017-12-01 17:50:22.439 [ERROR] [37.115.190.154:65194] [moddecompress+++] compressbuf in 0, inflate/deflate return -5
2017-12-01 18:01:26.487 [ERROR] [112.225.62.32:64228:HTTP2-1] [Module-Cache] createEntry failed.
2017-12-01 18:01:51.901 [ERROR] [112.225.62.32:64228:HTTP2-9] [Module-Cache] createEntry failed.
Can you disable Gzip compression, and check if you still get this error?
2024-04-20 21:16:26.543981 [ERROR] [181442] [46.248.185.96:44066#myweb.com] [moddecompress+++] compressbuf in 5868, inflate/deflate return -3
2024-04-21 14:42:15.500823 [ERROR] [181443] [136.243.60.30:54554#myweb.com] [moddecompress+++] compressbuf in 16384, inflate/deflate return -3
2024-04-26 15:14:53.519876 [ERROR] [309065] [136.243.60.30:48232#myweb.com] [moddecompress+++] compressbuf in 10217, inflate/deflate return -3
2024-05-24 15:59:39.619012 [ERROR] [680941] [136.243.60.30:52210#myweb.com] [moddecompress+++] compressbuf in 2345, inflate/deflate return -3
2024-06-02 08:31:57.944533 [ERROR] [680942] [114.218.152.230:52520:HTTP2-1#myweb.com] [moddecompress+++] compressbuf in 16384, inflate/deflate return -3
i gote this error when acsess my wordpres site
Request Timeout
This request takes too long to process, it is timed out by the server. If it should not be timed out, please contact administrator of this web site to increase ‘Connection Timeout’.
