I recently upgraded my CyberPanel installation to v1.9 Build 3E and after a few days I realized my backups were no longer operational.
In checking the crontab I noticed the backup entries were pointing to “python2” binary which appears to have been removed as part of the upgrade and replaced with “python3”.
I have confirmed my backups are back to running, so that issue has been resolved, however, when running “findBWUsage.py” I am getting the following error now:
[root@web01 ~]# python /usr/local/CyberCP/plogical/findBWUsage.py
File “/usr/local/CyberCP/plogical/findBWUsage.py”, line 2, in
from plogical import CyberCPLogFileWriter as logging
ImportError: No module named plogical
The first part of my post is just an FYI, second part I would like any advice y’all can share to get me back to an operational state.
I had some similiar case with backups, then I just did a fresh install then took the problematic .py file in my case it was backuplocal.py or sth like that and replaced where it was problem solved. You can do the same with replacing the problematic .py file with a fresh install
Don’t want to sound condescending but I would not have upgraded without taking a snapshot of the server first. Then if above occurred I could re-instate the snapshot and use updraft plugin to save wp sites for re-install after upgrade.
That said, if all is working and your only site backups are CyberPanel there must be a way to get them back.
ie/ re-install CyberPanel if the backups are stable and take it from there.
I have a full backup (many in this case) of the entire VM from before the upgrade was performed as well as the nightly backups created by CyberPanel itself.
As noted, my backups are fully operational once I had updated the crontab entries to use the new path for CyberPanel’s packaged python version (ie. python2 → python).
My post here is to serve as a bug report (Hence why I posted in the bug report section) as well as to ask for help with the bandwidth script.
The findBWUsage.py is the latest version from the installation repo.
My pleasure. I noticed that there was a slight issue as the user does not need to be specified when using the proper crontab.
As you already ran this here are two commands to fix this and remove the invalid crons in /etc/crontab.
sed -i ‘/CyberCP/d’ /etc/crontab
sed -i ‘s/root //g’ /var/spool/cron/root
I submitted a commit to fix this in both the install and the minor fix to upgrade.py usman pushed yesterday so this will be automatically fixed and checked for in all upgrades.
Showing a preview without modifiying file. Notice it remove just the bad crons in preview mode
root@server [/root]# sed ‘/CyberCP/d’ /etc/crontab
SHELL=/bin/bash
PATH=/sbin:/bin:/usr/sbin:/usr/bin
MAILTO=root
Now were going to safely only remove the bad cyberpanel crons from this file and root user in the crontab for the root user as its not needed.
root@server [/root]# sed -i ‘/CyberCP/d’ /etc/crontab
root@server [/root]# cat /etc/crontab
SHELL=/bin/bash
MAILTO=root
Hello, cron stats are fixed?
I did a new clean install and cron are not working
I tried update and got a lot of errors
I tested with Centos 7,8 and Ubuntu 18.04
