Hi everyone! Iβve been struggling with my CyberPanel setup for several days now, most likely because of my inexperience with back-end/server management. I hope the community here can give me a kickstart into solving this issue. If you would like to checkout the panel itself please request the login information to my in private.
Before I gave my machine a clean installation, I was running Homebridge using a docker-compose file. This was working and I was able to control all my network devices from one spot
However, I also wanted to play around with CyberPanel⦠I started a container from the image I pulled and followed several guides (both here and on other websites) to access the homebridge web UI.
I tried to use multiple setups (IP/port combination; 172.17.0.1, 172.0.0.1, [the public ip], :8581, :53109) in the /usr/local/lsws/conf/httpd_config.conf file and restarted the OpenLitespeed server every time.
Yet I keep getting the 503 error, no matter what I do.
I do not necessarily need to access the homebridge from a domain (better not actually), if it would work using internal ip (when connected through WiFi on the same network as the machine) that would best, however for my learning purpose I would like to know both options.
*sidenode, I did try to install multiple websites and DNS config and they where accessible (though I am stuck with self signed certificates, can someone tell me how the limit for LetβsEncrypt works? Is it weekly 1 per domain or per server?)
β Cheers Mike
------- below some reference since I could only upload one screenshot (please tell if troubleshoot information is missing ------
Enter this code with your HomeKit app on your iOS device to pair with Homebridge:
e[30me[47m e[49me[39m
e[30me[47m ββββββββββββββ e[49me[39m
e[30me[47m β 031-45-154 β e[49me[39m
e[37m[6/10/2022, 12:23:39 PM] e[39mHomebridge v1.4.1 (HAP v0.10.2) (Homebridge CEE1) is running on port 53109.
extprocessor dockerbackend {
type proxy
address 127.0.0.1:53109
maxConns 100
pcKeepAliveTimeout 60
initTimeout 60
retryTimeout 0
respBuffer 0
RewriteCond %{HTTPS} !=on
RewriteRule ^ https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
REWRITERULE ^(.*)$ http://dockerbackend/$1 [P]
docker0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 172.17.0.1 netmask 255.255.0.0 broadcast 172.17.255.255
inet6 fe80::42:59ff:fe35:e265 prefixlen 64 scopeid 0x20<link>
ether 02:42:59:35:e2:65 txqueuelen 0 (Ethernet)
RX packets 984 bytes 381328 (381.3 KB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 49 bytes 25170 (25.1 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
enp3s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.186 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::f279:59ff:fe93:1c6a prefixlen 64 scopeid 0x20<link>
inet6 fdfe:19a8:7365:0:f279:59ff:fe93:1c6a prefixlen 64 scopeid 0x0<global>
ether f0:79:59:93:1c:6a txqueuelen 1000 (Ethernet)
RX packets 20104 bytes 5969774 (5.9 MB)
RX errors 0 dropped 1867 overruns 0 frame 0
TX packets 10453 bytes 8550842 (8.5 MB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 9638 bytes 16359086 (16.3 MB)
TX packets 9638 bytes 16359086 (16.3 MB)
vethb544b61: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::fc0d:5dff:fedd:50e8 prefixlen 64 scopeid 0x20<link>
ether fe:0d:5d:dd:50:e8 txqueuelen 0 (Ethernet)
RX packets 984 bytes 395104 (395.1 KB)
TX packets 64 bytes 26316 (26.3 KB)
