Hello , i’m using cyberpanel more than 1 month now with this vps config :
8core cpu - 30go ram - 800ssd
i have linked my 10 domains to cloudflare then cyberpanel
but the big problem is the response of the server is very very slow
the panel show
CPU usage 60 - 80%
RAM 20%
SSD 5%
please help me !!!
do you install spam assasin ?
try check with htop from cli
thank you but when i can found this ?
no i didn’t instal spam assasin , how can found htop ? i’m just install cyeberpanel & activate the firewell thats all
how you install the cyberpanel ?
htop is an linux command to see the process tree
more like task manager (windows) and top (native linux command)
Loginizer – WordPress plugin | WordPress.org
try install this
or you can do this trick like at https://dug.my.id/
if someone access wp-admin it would redirect 301 random post lol
btw: nice spec i only run my cyberpanel using 1core and 2GB ram lol
only hosted 3-5 client…
how can i do this , i will install this plugin ,
thank you so much my friend
i need instal spam assasin or not ?
i hope it will solved . but; it cant guarantee 100%
there is many reason to get high usage
up to you
Spam assasin is only about email…
but it will took some resources of you server too… more email request , more resources
thank you my friend , but the problem not solved , can cloudflare make this problem ?
afaik… no…
try disable all themes and plugin from wp
Have you by any chance installed ElasticSearch module in cyberpanel?
no i didn’t install it , should i install it ? thank you
and check thats right ? why mysql use a lot of cpu ?
Which ubuntu version are you using? and when was the last time you updated cyberpanel?
please check this file and see if log-bin is enabled
/etc/mysql/my.cnf
ubuntu 18 - last update when i instal cyberpanel may be 3 month ago
Please re-run the upgrade command because there are a lot bug fixes and improvements done by now.
Also check you my.cnf file as mentioned above. There maybe log-bin enabled and hence server using heavy resources to log all the mysql operations
