root@localhost:~# systemctl status lscpd
● lscpd.service - LSCPD Daemon
Loaded: loaded (/etc/systemd/system/lscpd.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2022-02-19 01:02:34 UTC; 6min ago
Process: 75177 ExecStart=/usr/local/lscp/bin/lscpdctrl start (code=exited, status=1/FAILURE)
Feb 19 01:02:16 localhost systemd[1]: Starting LSCPD Daemon...
Feb 19 01:02:16 localhost lscpdctrl[75177]: [ERROR] Failed to start lscpd!
Feb 19 01:02:32 localhost lscpdctrl[75252]: lscpd: no process found
Feb 19 01:02:34 localhost lscpdctrl[75177]: [ERROR] Failed to start lscpd!
Feb 19 01:02:34 localhost systemd[1]: lscpd.service: Control process exited, code=exited, status=1/FAILURE
Feb 19 01:02:34 localhost systemd[1]: lscpd.service: Failed with result 'exit-code'.
Feb 19 01:02:34 localhost systemd[1]: Failed to start LSCPD Daemon.
root@localhost:~#
root@localhost:~# journalctl -xe
Feb 19 01:08:05 localhost sshd[75470]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=43.155.74.159
Feb 19 01:08:07 localhost sshd[75470]: Failed password for invalid user appuser from 43.155.74.159 port 40012 ssh2
Feb 19 01:08:07 localhost sshd[75470]: Received disconnect from 43.155.74.159 port 40012:11: Bye Bye [preauth]
Feb 19 01:08:07 localhost sshd[75470]: Disconnected from invalid user appuser 43.155.74.159 port 40012 [preauth]
Feb 19 01:08:27 localhost postfix/anvil[75371]: statistics: max connection rate 1/60s for (smtp:2.56.57.107) at Feb 19 01:05:06
Feb 19 01:08:27 localhost postfix/anvil[75371]: statistics: max connection count 1 for (smtp:2.56.57.107) at Feb 19 01:05:06
Feb 19 01:08:27 localhost postfix/anvil[75371]: statistics: max cache size 1 at Feb 19 01:05:06
Feb 19 01:09:00 localhost sshd[75498]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=122.155.0.205 user=root
Feb 19 01:09:01 localhost systemd[1]: Starting Clean php session files...
-- Subject: A start job for unit phpsessionclean.service has begun execution
-- Defined-By: systemd
-- Support: http://www.ubuntu.com/support
-- A start job for unit phpsessionclean.service has begun execution.
-- The job identifier is 2167.
Feb 19 01:09:01 localhost systemd[1]: phpsessionclean.service: Succeeded.
-- Subject: Unit succeeded
-- The unit phpsessionclean.service has successfully entered the 'dead' state.
Feb 19 01:09:01 localhost systemd[1]: Finished Clean php session files.
-- Subject: A start job for unit phpsessionclean.service has finished successfully
-- A start job for unit phpsessionclean.service has finished successfully.
Feb 19 01:09:01 localhost CRON[75550]: pam_unix(cron:session): session opened for user root by (uid=0)
Feb 19 01:09:01 localhost CRON[75551]: pam_unix(cron:session): session opened for user root by (uid=0)
Feb 19 01:09:01 localhost CRON[75553]: (root) CMD (/usr/local/CyberCP/bin/cleansessions >/dev/null 2>&1)
Feb 19 01:09:01 localhost CRON[75552]: pam_unix(cron:session): session opened for user root by (uid=0)
Feb 19 01:09:01 localhost CRON[75554]: (root) CMD ( [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Feb 19 01:09:01 localhost CRON[75557]: (root) CMD (if ! find /home/*/public_html/ -maxdepth 2 -type f -newer /usr/local/lsws/cgid -name '.htaccess' -exec false {} +; then systemctl restart lsws; fi)
Feb 19 01:09:01 localhost CRON[75550]: pam_unix(cron:session): session closed for user root
Feb 19 01:09:01 localhost CRON[75552]: pam_unix(cron:session): session closed for user root
Feb 19 01:09:01 localhost CRON[75551]: pam_unix(cron:session): session closed for user root
Feb 19 01:09:02 localhost sshd[75498]: Failed password for root from 122.155.0.205 port 13446 ssh2
Feb 19 01:09:02 localhost sshd[75498]: Received disconnect from 122.155.0.205 port 13446:11: Bye Bye [preauth]
Feb 19 01:09:02 localhost sshd[75498]: Disconnected from authenticating user root 122.155.0.205 port 13446 [preauth]
Feb 19 01:09:15 localhost sshd[75585]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=43.155.74.159 user=root
Feb 19 01:09:17 localhost sshd[75585]: Failed password for root from 43.155.74.159 port 35958 ssh2
Feb 19 01:09:18 localhost sshd[75585]: Received disconnect from 43.155.74.159 port 35958:11: Bye Bye [preauth]
Feb 19 01:09:18 localhost sshd[75585]: Disconnected from authenticating user root 43.155.74.159 port 35958 [preauth]
Feb 19 01:09:29 localhost sshd[75611]: error: kex_exchange_identification: Connection closed by remote host
root@localhost:~# cat /usr/local/lscp/logs/error.log
2022-02-19 00:30:36.502733 [ERROR] HttpListener::start(): Can't listen at address DefaultSSL: No such file or directory!
2022-02-19 00:30:36.502946 [ERROR] HttpServer::addListener(DefaultSSL) failed to create new listener
2022-02-19 00:30:36.502951 [ERROR] Failed to addListener <DefaultSSL> to port <:8090>.
how can I fix it?? Please help!
