Hello There
I need help..
when I do upgrade cyberpanel :
133|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: 220602 (215K) [text/plain]
Saving to: ‘upgrade.py’
upgrade.py 100%[===================>] 215.43K 512KB/s in 0.4s
2025-11-03 06:13:35 (512 KB/s) - ‘upgrade.py’ saved [220602/220602]
[2025-11-03 06:13:35] Starting Main_Upgrade function…
[2025-11-03 06:13:35] Running: /usr/local/CyberPanel/bin/python upgrade.py v2.4.4
Same. Looks like playing russian roulette when upgrading the cyberpanel, always glitching, always an error. I think I will switch to Plesk.
Can you please tell me if at this step update is taking time or just getting stuck and then never responding or is terminated from here?
Same thing happened to me. The whole update process just stopped there and never responding again even after 30 minutes. Please advise
izzis
5
check /home/cyberpanel/upgrade_logs
I thought it was stuck forever, it just downloading too slow
[01.05.2026_11-34-26] Existing ModSecurity detected - downloading compatible version...
[01.05.2026_11-34-26] #########################################################################
[01.05.2026_11-34-26] Downloading mod_security.so...
[01.05.2026_11-42-39] #########################################################################
[01.05.2026_11-42-39] Downloaded successfully (76.24 MB)
