i try to upgrade php version from “edit php configs” and it’s ok and return success message, but still not upgraded to vps , when i check php version with command
php -v
return current version is 7.4
php -v
from the php manager you cant update the server PHP version check linux - How can I change php-cli version on Ubuntu 14.04? - Stack Overflow hope it will help
path is sightly different in lsphp
i use centOS, and try many times but can’t.
php 8.1 already setup but when i run command php -v return 7.4
Check this to change php cli version
