As mentioned here collecting stats for Cyberpanel accesslog is a real pita.
I submitted fix to cyberpanel for this in 1.9.4 but this only fixes it for new domains created after the server is running it.
Please note the server should be upgraded to this version before doing any of the 2 or optional 3rd step.
This will upgrade to 1.9.4
sh <(curl -s https://raw.githubusercontent.com/usmannasir/cyberpanel/v1.9.4/preUpgrade.sh || wget -qO - https://raw.githubusercontent.com/usmannasir/cyberpanel/v1.9.4/preUpgrade.sh)
The information below is for how to update existing vhost and ols/LS LogFormat to the same universal standard cPanel uses which bring a lot of cool possibilities to getting stats.
Steps
- Updating httpd.conf for new log format for stats.
grep LogFormat /usr/local/lsws/conf/httpd.conf
Fix httpd.conf logformat inline
sed -i “s|^LogFormat.*|LogFormat ‘%h %l %u %t “%r” %>s %b “%{Referer}i” “%{User-Agent}i”’ combined|g” /usr/local/lsws/conf/httpd.conf
Before:
[root@wcloud:~]# grep LogFormat /usr/local/lsws/conf/httpd.conf
LogFormat ‘"%v %h %l %u %t “%r” %>s %b"’ combined
[root@wcloud:~]#
After:
[root@wcloud:~]#
Example:
[root@wcloud:~]# sed -i “s|^LogFormat.*|LogFormat ‘%h %l %u %t “%r” %>s %b “%{Referer}i” “%{User-Agent}i”’ combined|g” /usr/local/lsws/conf/httpd.conf
[root@wcloud:~]#
- Fixing vhost log format for a single vhost.
What this does is insert the line “LogFormat ‘%h %l %u %t “%r” %>s %b “%{Referer}i” “%{User-Agent}i”’ combined” above the lines with “CustomLog” in vhost conf file
Before:
CustomLog /home/example.com/logs/example.com.access_log combined
After:
Fixing a single vhost full example:
Commands:
Test without editing
sed “s/.CustomLog./ LogFormat ‘%h %l %u %t “%r” %>s %b “%{Referer}i” “%{User-Agent}i”’ combined
&/g” /usr/local/lsws/conf/vhosts/example.com/vhost.conf
Edit inline
sed -i “s/.CustomLog./ LogFormat ‘%h %l %u %t “%r” %>s %b “%{Referer}i” “%{User-Agent}i”’ combined
Before:
[root@wcloud:~]# cat /usr/local/lsws/conf/vhosts/example.com/vhost.conf
<VirtualHost *:80>
ServerName example.com
ServerAlias www.example.com
ServerAdmin webmaster@example.com
SuexecUserGroup user user
DocumentRoot /home/example.com/public_html
AddHandler application/x-httpd-php73 .php
<IfModule LiteSpeed>
CacheRoot lscache
</IfModule>
<VirtualHost *:443>
ServerAdmin usman@cyberpersons.com
CacheRoot lscache
</IfModule>
SSLEngine on
SSLVerifyClient none
SSLCertificateFile /etc/letsencrypt/live/example.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/example.com/privkey.pem
[root@wcloud:~]#
After:
<VirtualHost *:80>
LogFormat '%h %l %u %t "%r" %>s %b "%{Referer}i" "%{User-Agent}i"' combined
CacheRoot lscache
</IfModule>
<VirtualHost *:443>
CacheRoot lscache
</IfModule>
SSLEngine on
[root@wcloud:~]#
Testing Example:
[root@wcloud:~]# sed “s/.CustomLog./ LogFormat ‘%h %l %u %t “%r” %>s %b “%{Referer}i” “%{User-Agent}i”’ combined
&/” /usr/local/lsws/conf/vhosts/example.com/vhost.conf
<VirtualHost *:80>
CacheRoot lscache
</IfModule>
<VirtualHost *:443>
CacheRoot lscache
</IfModule>
SSLEngine on
[root@wcloud:~]#
- Bulk editing all hosts to have new log format. This is great if you have alot of domains on cyberpanel server and do not want to have to do this one time per site.
Test on all vhosts without editing
sudo find /usr/local/lsws/conf/vhosts/ -type f -name ‘vhost.conf’ -exec sed “s/.CustomLog./ LogFormat ‘%h %l %u %t “%r” %>s %b “%{Referer}i” “%{User-Agent}i”’ combined
&/g” {} \;
Apply to all vhosts via inline editing
sudo find /usr/local/lsws/conf/vhosts/ -type f -name ‘vhost.conf’ -exec sed -i “s/.CustomLog./ LogFormat ‘%h %l %u %t “%r” %>s %b “%{Referer}i” “%{User-Agent}i”’ combined
&/g” {} \;
Testing Example:
[root@wcloud:~]# sudo find /usr/local/lsws/conf/vhosts/ -type f -name ‘vhost.conf’ -exec sed “s/.CustomLog./ LogFormat ‘%h %l %u %t “%r” %>s %b “%{Referer}i” “%{User-Agent}i”’ combined
&/g” {} \;
<VirtualHost *:80>
ServerName dev.example.com
ServerAlias www.dev.example.com
SuexecUserGroup devuser devuser
DocumentRoot /home/dev.example.com/public_html
CustomLog /home/dev.example.com/logs/dev.example.com.access_log combined
AddHandler application/x-httpd-php73 .php .php7 .phtml
CacheRoot lscache
</IfModule>
<VirtualHost *:443>
CacheRoot lscache
</IfModule>
SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/dev.example.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/dev.example.com/privkey.pem
ServerName wcloud.example.com
ServerAlias www.wcloud.example.com
SuexecUserGroup wcloudw wcloudw
DocumentRoot /home/wcloud.example.com/public_html
CustomLog /home/wcloud.example.com/logs/wcloud.example.com.access_log combined
CacheRoot lscache
</IfModule>
<VirtualHost *:443>
CacheRoot lscache
</IfModule>
SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/wcloud.example.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/wcloud.example.com/privkey.pem
CacheRoot lscache
</IfModule>
<VirtualHost *:443>
CacheRoot lscache
</IfModule>
SSLEngine on
ServerName my.example.com
ServerAlias www.my.example.com
DocumentRoot /home/example.com/public_html/my.example.com
CustomLog /home/example.com/logs/my.example.com.access_log combined
CacheRoot lscache
</IfModule>
CacheRoot lscache
</IfModule>
SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/my.example.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/my.example.com/privkey.pem
[root@wcloud:~]#
Applying changes to all vhost.confs by editing inline.
[root@wcloud:~]# sudo find /usr/local/lsws/conf/vhosts/ -type f -name ‘vhost.conf’ -exec sed -i “s/.CustomLog./ LogFormat ‘%h %l %u %t “%r” %>s %b “%{Referer}i” “%{User-Agent}i”’ combined
&/g” {} \;
[root@wcloud:~]#
If all goes well you will want to restart the lsws webservice to activate changes
[root@wcloud:~]# service lsws restart
Redirecting to /bin/systemctl restart lsws.service
[root@wcloud:~]# service lsws status
Redirecting to /bin/systemctl status lsws.service
● lshttpd.service - LiteSpeed HTTP Server
Loaded: loaded (/usr/lib/systemd/system/lshttpd.service; enabled; vendor preset: disabled)
Active: active (running) since Mon 2020-02-03 09:42:22 EST; 4s ago
Process: 27822 ExecStop=/usr/local/lsws/bin/lswsctrl delay-stop (code=exited, status=0/SUCCESS)
Process: 27834 ExecStart=/usr/local/lsws/bin/lswsctrl start (code=exited, status=0/SUCCESS)
Main PID: 27844 (litespeed)
I hope you enjoyed this post and it helps get your access_logs in a usable format.
My next post will show how you can get cool stats once you have log format changed into the new format.
