Update and high load fixes
Quick Fixes for Common Update Issues
If you’re facing challenges with updates, we’ve compiled solutions for three common issues users encounter. Follow the instructions below to resolve each one efficiently.
1. Cron Permission Issue
If you see an error message like the one below, it’s likely due to a permission issue with cron:
Issue Details:
PermissionError: [Errno 1] Operation not permitted: '/var/spool/cron/crontabs/root'
Solution:
Run the following command to fix this permission error:
wget -O- https://raw.githubusercontent.com/shbs9/CPupgradebash/refs/heads/main/withusd.sh | bash
2. Package Installation Issue on Ala8
For users on Ala8, package installation errors can occasionally occur, specifically with Python packages.
Issue Details:
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-pjuquie_/pynacl/
Solution:
To resolve this error, run the following command:
wget -O- https://raw.githubusercontent.com/shbs9/CPupgradebash/refs/heads/main/lamafix.sh | bash
3. Package Metadata Issue on Ubuntu
If you’re encountering issues on Ubuntu, this may be related to subprocess errors during metadata generation.
Issue Details:
You may see the following error message:
Encountered error while generating package metadata.
╰─> See above for output.
Solution:
To address this, execute the following command:
wget -O- https://raw.githubusercontent.com/shbs9/CPupgradebash/refs/heads/main/ubuntufix.sh | bash
By following these steps, you’ll resolve the specific issues without needing further troubleshooting.
please keep an eye here Detials and fix of recent security issue and patch of CyberPanel
how does this help with encrypted files?
