How can I uninstall Mautic or Delete the installation.
I’m afraid that I made a mistake.
Want to start all over again with a new fresh installation.
Thanks
Thanks
Go to the webiste directory and remove all file all done make sure that you’ll only remove that websites file. you you have that setup speratly for the muatic then delete that website and create agian
Hey, thanks!
Deleted all the folders and files in the; public_html
Did a new and fresh Mautic install with a default website.
After installation of Mautic, my site looks like this: https://mbo.hipamo.com/
Checked if I have a index.php in the new public_html and I have.
What else can be wrong?
