i cannot access into my website. it shows unable to connect. what happened with this? i cleared some cache and deleted tmp folder, from that time i cannot access in my website and wordpress also.
Was it working before? Share lsws error logs file data.
ya it was working fine previously…
here is error log data:-
tail: cannot open ‘/usr/local/lsws/logs/error.log’ for reading: No such file or directory
ls -la /usr/local/lsws
hi usmannasir,
what should i do now, would you suggest me, im having trouble and cannot access my website from yesterday.
do you have disk space?
/usr/local/lsws/bin/lshttpd -t
cat /usr/local/lsws/conf/httpd_config.conf
open this file using nano and and remove start from module mod_security to the end of file and restart systemctl restart lsws
would u please tell me where to and how to open nano, ,what’s nano actually! ![]()
ya i opened nano… now what to do
It is better that you hire someone to look into this. Because I’ve already explained what to do above, and if you do anything I fear you may further break your system.
We’ve a paid support option on CyberPanel cloud.
Because judging by your answers I feel you don’t know much about linux,
ya…will cyber panel enterprise work for me?
First need to figure out the issue with your server.
