I am currently facing issues with accessing both CyberPanel and WordPress on my server. After performing some troubleshooting and configuration changes, I encountered different errors that I need help resolving. Below is a detailed account of the steps I took and the current state of the system.
Background:
- Initial Issue:
- CyberPanel and WordPress were initially inaccessible due to database connection issues.
- The error for CyberPanel was:
OperationalError at / (2002, "Can't connect to local server through socket '/run/mysqld/mysqld.sock' (2)"). - The error for WordPress was:
Error establishing a database connection.
- Steps Taken:
- Verified MariaDB configuration files (
/etc/mysql/my.cnfand/etc/mysql/mariadb.conf.d/50-server.cnf) to ensure correct settings. - Checked the MariaDB service status and socket file, which are now correctly created and active.
Current Issues:
- CyberPanel:
- The error has changed to:
ProgrammingError at / (1146, "Table 'cyberpanel.loginSystem_administrator' doesn't exist"). - It appears that some tables might be missing or the database might be corrupted.
- WordPress:
- The error remains the same:
Error establishing a database connection. - Ensured correct database credentials in
wp-config.phpand verified the presence of the MariaDB socket file. - Note: The WordPress websites on the server display posts, images, and data correctly, but the WordPress admin dashboard shows the
Error establishing a database connectionerror.
Details:
- MariaDB Configuration Files:
/etc/mysql/my.cnf:
[mysqld]
user = mysql
pid-file = /run/mysqld/mysqld.pid
socket = /var/lib/mysql/mysql.sock
basedir = /usr
datadir = /var/lib/mysql
tmpdir = /tmp
bind-address = 0.0.0.0
log-error = /var/log/mysql/error.log
# Additional recommended settings for InnoDB
innodb_buffer_pool_size = 128M
innodb_log_file_size = 48M
innodb_file_per_table = 1
[client]
port=3306
socket=/var/lib/mysql/mysql.sock
/etc/mysql/mariadb.conf.d/50-server.cnf:
[server]
[mysqld]
user = mysql
basedir = /usr
tmpdir = /tmp
# * Character sets
character-set-server = utf8mb4
collation-server = utf8mb4_general_ci
[mariadbd]
innodb_log_file_size=48M
[mariadb-11.1]
- Socket File Verification:
root@vmi1011023:~# ls -l /run/mysqld/
total 4
-rw-rw---- 1 mysql mysql 7 Jul 3 20:08 mysqld.pid
srwxrwxrwx 1 mysql mysql 0 Jul 3 20:08 mysqld.sock
- CyberPanel Database Configuration:
DATABASES = {
'default': {
'ENGINE': 'django.db.backends.mysql',
'NAME': 'cyberpanel',
'USER': 'cyberpanel',
'PASSWORD': 'Dzkcdkmf2GDE2',
'HOST': 'localhost',
'PORT':''
'rootdb': {
'NAME': 'mysql',
'USER': 'root',
'PASSWORD': 'IiN5iBgEQhlL2q',
'PORT': '',
Request for Assistance:
I kindly request guidance on the following:
- How to restore or reinitialize the missing
cyberpanel.loginSystem_administratortable. - Ensuring that WordPress can connect to the database without errors.
Any help or suggestions would be greatly appreciated. Thank you in advance for your support.
