Hi there,
I running on Centos 7 with CP 1.9.1 (OLS 1.5.7).
I came to the point that I needed to tweak a little mysql settings, so I went for info and got little confused.
I assumed that all settings can be loaded by etc/mysql.conf.d/server.cnf (which is empty by default or precisely doesn’t have anything but [mysqld] and some #info)
So I put only test stuff below [mysqld] such as:
max_connections = 265
innodb_buffer_pool_size = 512M
query_cache_limit = 2M
query_cache_size = 32M
→ saved
→ systemctl restart mysqld
nothing appeared in php info
→ systemctl restart lscpd
same nothing
So I started reading … setting can be made by panel.cyberpanel.net , went there but that option is off for adding new servers.
Now I stuck and got more confused, where and how make necessary changes,? I am wrong with etc/mysql.conf.d/server.cnf ?
Anyone was facing similar problem?
