Step 1: Install CyberPanel and Create Website
You first need to install CyberPanel and create your website . Skip this step if you have already done so. You can also issue SSL for this website.
I will be using svelte.mydomain.com as my example for this so change this to whatever your website domain is.
Step 2: Install Node.js via Command Line
Next step is to install Node.js via command line
$ cd ~
$ curl -fsSL https://deb.nodesource.com/setup_16.x | sudo -E bash - &&\
Refer to the NodeSource documentation for more information on the available versions and instllation process for CentOS and AlmaLinux
$ sudo apt-get install -y nodejs
$ node -v
Step 3: Setup a Reverse Proxy
Follow this tutorial on how to Reverse Proxy a website then continue below.
Step 4: Setup AppServer Context to Serve SvelteKit Application
Open website launcher by visiting https:// < IP Address >:8090/websites/svelte.mydomain.com and click vHost conf to add the following context configurations, make sure this is on your backend website where your server files are located.
context / {
type appserver
location /home/svelte.mydomain.com/public_html/backend
binPath /usr/bin/node
appType node
maxConns 100
rewrite {
addDefaultCharset off
Step 5: Start SvelteKit Application
In my case i goto where my website files are located on my backened and type in this order:
npm install
npm run build
cd build
pm2 start index.js
Once all these steps are done you should have a working SvelteKit Application ran through a Reverse Proxy ![]()
