My first question … does Cyberpanel require Litespeed to be installed already, or does the installation script handle all that?
I couldn’t make that determination just from the installation doc (Installing CyberPanel - CyberPanel) so I went through the whole installation and setup of a clean install of OpenLitespeed on a new Digital Ocean droplet before attempting to install Cyberpanel.
I have the Centos firewall enabled, and I also made sure port 8090 was turned on, but I get a connection refused error. I’m sure I made a major error in the order of installing.
When running the install script I get the following …
`sudo sh <(curl https://cyberpanel.net/install.sh || wget -O - https://cyberpanel.net/install.sh)
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0sh: /dev/fd/63: No such file or directory
100 1229 100 1229 0 0 3482 0 --:--:-- --:--:-- --:--:-- 3481
(23) Failed writing body
--2018-06-17 04:39:10-- https://cyberpanel.net/install.sh
Resolving cyberpanel.net (cyberpanel.net)... 35.196.228.222
Connecting to cyberpanel.net (cyberpanel.net)|35.196.228.222|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1229 (1.2K) [application/x-sh]
Saving to: ‘STDOUT’
0% [ ] 0 --.-K/s in 0s
Cannot write to ‘-’ (Success).`
I am at a complete loss as to where to go next.
Please advise, thank you ... Scott
`sudo sh <(curl https://mirror.cyberpanel.net/index.html?action=download)
100 13103 0 13103 0 0 16538 0 --:--:-- --:--:-- --:--:-- 16544[sudo] password for prockstar:
sh: /dev/fd/63: No such file or directory`
The server is a brand new Centos 7 droplet on DigitalOcean, 50GB disk space, 2GB ram. The only thing on it would be the OpenLitespeed installation and it's dependancies.
I would normally try and find out why I'm getting a "No such file" error on /dev/fd/63 but without looking at the install script, there's no other instructions to reference for troubleshooting.
After looking at other tutorials online it’s appearing as if I didn’t need to install OLS first. Surely I can’t be the only one not knowing if the Cyberpanel install script handles the installation of OLS too :#
sooooo … yepper … the Cyberpanel install does NOT need Litespeed installed.
The installer works great, the only snag I came across was when trying to run the the python script ( install.py ) as sudo, I ended up with permission errors. Running as root worked flawlessly, not the biggest fan of installing with root, but it’s working now.
