today i got 1 SSL error
After editing a few things . I did not get into admin 8090.
Please help me
error.log
2021-06-17 11:54:40.071205 [INFO] [PlainConf] [httpServerConfig:] module [mod_security] add param [secauditlogtype Serial]
2021-06-17 11:54:40.071207 [INFO] [PlainConf] [httpServerConfig:] module [mod_security] add param [secauditlog /usr/local/lsws/logs/auditmodsec.log]
2021-06-17 11:54:40.071209 [INFO] [PlainConf] [httpServerConfig:] module [mod_security] add param [secruleengine On]
2021-06-17 11:54:40.071210 [INFO] [PlainConf] [httpServerConfig:] module [mod_security] add param [` ]
2021-06-17 11:54:40.071212 [INFO] [PlainConf] [httpServerConfig:] module [mod_security] add param [modsecurity_rules_file /usr/local/lsws/conf/modsec/rules.conf]
2021-06-17 11:54:40.071224 [NOTICE] Loading LiteSpeed/1.7.11 Open
module versions:
modgzip 1.1
cache 1.62
modinspector 1.1
uploadprogress 1.1
mod_security 1.4
(built: Mon Jun 7 13:05:24 UTC 2021) …
2021-06-17 11:54:40.071230 [NOTICE] Using [BoringSSL]
2021-06-17 11:54:40.082420 [NOTICE] [ADMIN] server socket: uds://usr/local/lsws/admin/tmp/admin.sock.7004, fd 6.
2021-06-17 11:54:40.082651 [NOTICE] [10674] chroot is disabled.
2021-06-17 11:54:40.082669 [INFO] [10674] old priority: 0, new priority: 0
2021-06-17 11:54:40.082716 [INFO] [10674] [config:server:basics2] For better obscurity, server version number is hidden in the response header.
2021-06-17 11:54:40.083644 [INFO] [10674] setuid is allowed in Ext Apps
2021-06-17 11:54:40.083982 [NOTICE] [10674] [PID: 10674]: forked cgid: 10677
2021-06-17 11:54:40.084097 [INFO] [10674] [PlainConf] [adminConfig:] start parsing file /usr/local/lsws/admin/conf/admin_config.conf
2021-06-17 11:54:40.084415 [INFO] [10674] [PlainConf] [adminConfig:] Finished parsing file /usr/local/lsws/admin/conf/admin_config.conf
2021-06-17 11:54:40.085889 [INFO] [10674] QuicEngine::init(), pid: 10674, log level [warn].
2021-06-17 11:54:40.088490 [INFO] [10674] [Module:mod_security] ParseConfig entry, level 1, Mod_Security v3.0.4
2021-06-17 11:54:40.089094 [INFO] [10674] [Module:mod_security] Enable flag interpreted as 1
2021-06-17 11:54:40.089104 [INFO] [10674] [Module:mod_security] setSecRule value:
secdebugloglevel 0
secdebuglog /usr/local/lsws/logs/modsec.log
secauditengine on
secauditlogrelevantstatus “^(?:5|4(?!04))”
secauditlogparts AFH
secruleengine On
, type: 1
2021-06-17 11:54:40.089768 [INFO] [10674] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/rules.conf, type: 2
2021-06-17 11:54:40.090279 [INFO] [10674] [Module: modcompress 1.1] has been initialized successfully
2021-06-17 11:54:40.090346 [INFO] [10674] [Module: moddecompress 1.1] has been initialized successfully
2021-06-17 11:54:40.090410 [INFO] [10674] [Module: cache 1.62] has been initialized successfully
2021-06-17 11:54:40.090469 [INFO] [10674] [Module: mod_security mod_s
[root@cyberpanel ~]# systemctl status lsws
● lshttpd.service - OpenLiteSpeed HTTP Server
Loaded: loaded (/usr/lib/systemd/system/lshttpd.service; enabled; vendor preset: disabled)
Active: activating (start) since Thu 2021-06-17 13:33:48 UTC; 29s ago
Process: 55182 ExecStart=/usr/local/lsws/bin/lswsctrl start (code=exited, status=0/SUCCESS)
Main PID: 2222 (code=exited, status=1/FAILURE)
CGroup: /system.slice/lshttpd.service
└─55233 openlitespeed (lscgid)
Jun 17 13:33:48 cyberpanel systemd[1]: lshttpd.service holdoff time over, scheduling restart.
Jun 17 13:33:48 cyberpanel systemd[1]: Stopped OpenLiteSpeed HTTP Server.
Jun 17 13:33:48 cyberpanel systemd[1]: Starting OpenLiteSpeed HTTP Server…
Jun 17 13:33:49 cyberpanel lswsctrl[55182]: [OK] litespeed: pid=55200.
Jun 17 13:33:53 cyberpanel lswsctrl[55182]: [OK] litespeed: pid=55226.
Jun 17 13:33:53 cyberpanel systemd[1]: New main PID 55226 does not exist or is a zombie.
