TLS/SSL issues
I have tried updating the SSL for mail.stripps.io by both issuing a new Lets Encrypt SSL and by manually pasting in the wildcard SSL I have purchased bu no matter what I do I cannot //email/testTo: to see the new SSL. It is reporting the SSL has expired but when I run a web server SSL test the SSL is fine. I’m obviously missing something! Its like its cached some where but I have restarted dovecot, postfix and the whole server a number of times with no luck.
Help would be appreciated!!!
The server has mail on mail.qwikz.com and I have a few domains on it - all of which run the same code. The only issue is that when I try to send mail from stripps.io I get the following in the email log:
Jun 24 06:59:15 mail postfix/smtpd[36294]: connect from mail.qwikz.com[212.71.255.85]
Jun 24 06:59:15 mail postfix/smtpd[36294]: SSL_accept error from mail.qwikz.com[212.71.255.85]: 0
Jun 24 06:59:15 mail postfix/smtpd[36294]: warning: TLS library problem: error:14094415:SSL routines:ssl3_read_bytes:sslv3 alert certificate expired:s3_pkt.c:1493:SSL alert number 45:
Jun 24 06:59:15 mail postfix/smtpd[36294]: lost connection after STARTTLS from mail.qwikz.com[212.71.255.85]
Jun 24 06:59:15 mail postfix/smtpd[36294]: disconnect from mail.qwikz.com[212.71.255.85] ehlo=1 starttls=0/1 commands=1/2
So I was checking the SSL certs and all was fine, then I thought perhaps its something to do with the stripps.io domain as its the one wanting to send an email. Checking the domain stripps.io in //email/testTo: reports an expired Lets Encrypt SSL but that domain is actually using a paid SSL.
I ran the command you mentioned and got the following:
Jun 24 07:14:19 mail postfix/postmap[37253]: warning: /etc/postfix/vmail_ssl.map.db: duplicate entry: “mail.stripps.io
Jun 24 07:14:19 mail postfix/postmap[37253]: warning: /etc/postfix/vmail_ssl.map.db: duplicate entry: “mail.abc-dev.co.uk
Looks like there could be an issue with duplicates like I thought?
PS thanks for the reply!
That now seems to be working actually.
I have removed the duplicate lines in the file and re-run the command and no duplicates are now reported. My last question would be why is this using a Lets Encrypt SSL while checking the site SSL returns my paid SSL?
Thanks again
