Hello I cannot apply the ssl in the subdomain where cyber panel is installed, for example my main domain is mysite.com in which if ssl works and my subdomain is test.mysite.com and there the ssl is not applied correctly
Hello, is that the only solution?
Perfect thanks
Hi, do you have a solution?
