I just installed CyberPanel on centos 8 and Current Version 2.1. When I added a domain and i clicked in Issue SSL the domain SSL which was assigned is www.example.com with below details
CN = www.example.com
O = Dis
L = Springfield
S = Denial
C = US
How can I fix this issue ? I did try to go to MANAGE SSL and issue the SSL again but still the same issue. For some reason the Let’s Encrypt SSL is not working
I had a similar issue today. I solved mine by running “wget -O - https://get.acme.sh | sh” then try to issue the cert again. something to do having an older version of acme. “ERROR: certbot 0.21.1 has requirement acme==0.21.1, but you’ll have acme 1.9.0 which is incompatible.”
