Dears,
After updating to 2.3.1 and Rebooting I got an error message about ACME file missing so I followed the steps to install or update Acme.
Now I cant issue the hosting SSL certificate.
/root/.acme.sh/acme.sh --issue -d panel.chilevapo.cl -d www.panel.chilevapo.cl --cert-file /etc/letsencrypt/live/panel.chilevapo.cl/cert.pem - -key-file /etc/letsencrypt/live/panel.chilevapo.cl/privkey.pem --fullchain-file /etc/letsencrypt/live/panel.chilevapo.cl/fullchain.pem -w /usr/local/lsws/Exa mple/html -k ec-256 --force --server letsencrypt --debug --log
[Fri 29 Apr 2022 06:36:05 PM UTC] Selected server: https://acme-v02.api.letsencrypt.org/directory
[Fri 29 Apr 2022 06:36:05 PM UTC] Lets find script dir.
[Fri 29 Apr 2022 06:36:05 PM UTC] _SCRIPT_='/root/.acme.sh/acme.sh'
[Fri 29 Apr 2022 06:36:05 PM UTC] _script='/root/.acme.sh/acme.sh'
[Fri 29 Apr 2022 06:36:05 PM UTC] _script_home='/root/.acme.sh'
[Fri 29 Apr 2022 06:36:05 PM UTC] Using config home:/root/.acme.sh
https://github.com/acmesh-official/acme.sh
v3.0.3
[Fri 29 Apr 2022 06:36:05 PM UTC] Using server: letsencrypt
[Fri 29 Apr 2022 06:36:05 PM UTC] Running cmd: issue
[Fri 29 Apr 2022 06:36:05 PM UTC] _main_domain='panel.chilevapo.cl'
[Fri 29 Apr 2022 06:36:05 PM UTC] _alt_domains='www.panel.chilevapo.cl'
[Fri 29 Apr 2022 06:36:05 PM UTC] ACME_DIRECTORY='https://acme-v02.api.letsencrypt.org/directory'
[Fri 29 Apr 2022 06:36:05 PM UTC] DOMAIN_PATH='/root/.acme.sh/panel.chilevapo.cl_ecc'
[Fri 29 Apr 2022 06:36:05 PM UTC] Le_NextRenewTime
[Fri 29 Apr 2022 06:36:05 PM UTC] Using ACME_DIRECTORY: https://acme-v02.api.letsencrypt.org/directory
[Fri 29 Apr 2022 06:36:05 PM UTC] _init api for server: https://acme-v02.api.letsencrypt.org/directory
[Fri 29 Apr 2022 06:36:05 PM UTC] GET
[Fri 29 Apr 2022 06:36:05 PM UTC] url='https://acme-v02.api.letsencrypt.org/directory'
[Fri 29 Apr 2022 06:36:05 PM UTC] timeout=
[Fri 29 Apr 2022 06:36:05 PM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header -L -g '
[Fri 29 Apr 2022 06:36:06 PM UTC] ret='0'
[Fri 29 Apr 2022 06:36:06 PM UTC] ACME_KEY_CHANGE='https://acme-v02.api.letsencrypt.org/acme/key-change'
[Fri 29 Apr 2022 06:36:06 PM UTC] ACME_NEW_AUTHZ
[Fri 29 Apr 2022 06:36:06 PM UTC] ACME_NEW_ORDER='https://acme-v02.api.letsencrypt.org/acme/new-order'
[Fri 29 Apr 2022 06:36:06 PM UTC] ACME_NEW_ACCOUNT='https://acme-v02.api.letsencrypt.org/acme/new-acct'
[Fri 29 Apr 2022 06:36:06 PM UTC] ACME_REVOKE_CERT='https://acme-v02.api.letsencrypt.org/acme/revoke-cert'
[Fri 29 Apr 2022 06:36:06 PM UTC] ACME_AGREEMENT='https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf'
[Fri 29 Apr 2022 06:36:06 PM UTC] ACME_NEW_NONCE='https://acme-v02.api.letsencrypt.org/acme/new-nonce'
[Fri 29 Apr 2022 06:36:06 PM UTC] Using CA: https://acme-v02.api.letsencrypt.org/directory
[Fri 29 Apr 2022 06:36:06 PM UTC] _on_before_issue
[Fri 29 Apr 2022 06:36:06 PM UTC] _chk_main_domain='panel.chilevapo.cl'
[Fri 29 Apr 2022 06:36:06 PM UTC] _chk_alt_domains='www.panel.chilevapo.cl'
[Fri 29 Apr 2022 06:36:06 PM UTC] Le_LocalAddress
[Fri 29 Apr 2022 06:36:06 PM UTC] d='panel.chilevapo.cl'
[Fri 29 Apr 2022 06:36:06 PM UTC] Check for domain='panel.chilevapo.cl'
[Fri 29 Apr 2022 06:36:06 PM UTC] _currentRoot='/usr/local/lsws/Example/html'
[Fri 29 Apr 2022 06:36:06 PM UTC] d='www.panel.chilevapo.cl'
[Fri 29 Apr 2022 06:36:06 PM UTC] Check for domain='www.panel.chilevapo.cl'
[Fri 29 Apr 2022 06:36:06 PM UTC] _saved_account_key_hash is not changed, skip register account.
[Fri 29 Apr 2022 06:36:06 PM UTC] Read key length:ec-256
[Fri 29 Apr 2022 06:36:06 PM UTC] _createcsr
[Fri 29 Apr 2022 06:36:06 PM UTC] Multi domain='DNS:panel.chilevapo.cl,DNS:www.panel.chilevapo.cl'
[Fri 29 Apr 2022 06:36:06 PM UTC] Getting domain auth token for each domain
[Fri 29 Apr 2022 06:36:06 PM UTC] url='https://acme-v02.api.letsencrypt.org/acme/new-order'
[Fri 29 Apr 2022 06:36:06 PM UTC] payload='{"identifiers": [{"type":"dns","value":"panel.chilevapo.cl"},{"type":"dns","value":"www.panel.chilevapo.cl"}]}'
[Fri 29 Apr 2022 06:36:06 PM UTC] RSA key
[Fri 29 Apr 2022 06:36:06 PM UTC] HEAD
[Fri 29 Apr 2022 06:36:06 PM UTC] _post_url='https://acme-v02.api.letsencrypt.org/acme/new-nonce'
[Fri 29 Apr 2022 06:36:06 PM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header -L -g -I '
[Fri 29 Apr 2022 06:36:06 PM UTC] _ret='0'
[Fri 29 Apr 2022 06:36:06 PM UTC] POST
[Fri 29 Apr 2022 06:36:06 PM UTC] _post_url='https://acme-v02.api.letsencrypt.org/acme/new-order'
[Fri 29 Apr 2022 06:36:06 PM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header -L -g '
[Fri 29 Apr 2022 06:36:07 PM UTC] _ret='0'
[Fri 29 Apr 2022 06:36:07 PM UTC] code='201'
[Fri 29 Apr 2022 06:36:07 PM UTC] Le_LinkOrder='https://acme-v02.api.letsencrypt.org/acme/order/517313827/84383722547'
[Fri 29 Apr 2022 06:36:07 PM UTC] Le_OrderFinalize='https://acme-v02.api.letsencrypt.org/acme/finalize/517313827/84383722547'
[Fri 29 Apr 2022 06:36:07 PM UTC] url='https://acme-v02.api.letsencrypt.org/acme/authz-v3/103401127637'
[Fri 29 Apr 2022 06:36:07 PM UTC] payload
[Fri 29 Apr 2022 06:36:07 PM UTC] POST
[Fri 29 Apr 2022 06:36:07 PM UTC] _post_url='https://acme-v02.api.letsencrypt.org/acme/authz-v3/103401127637'
[Fri 29 Apr 2022 06:36:07 PM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header -L -g '
[Fri 29 Apr 2022 06:36:07 PM UTC] code='200'
[Fri 29 Apr 2022 06:36:07 PM UTC] url='https://acme-v02.api.letsencrypt.org/acme/authz-v3/103401127647'
[Fri 29 Apr 2022 06:36:07 PM UTC] _post_url='https://acme-v02.api.letsencrypt.org/acme/authz-v3/103401127647'
[Fri 29 Apr 2022 06:36:08 PM UTC] d='panel.chilevapo.cl'
[Fri 29 Apr 2022 06:36:08 PM UTC] Getting webroot for domain='panel.chilevapo.cl'
[Fri 29 Apr 2022 06:36:08 PM UTC] _w='/usr/local/lsws/Example/html'
[Fri 29 Apr 2022 06:36:08 PM UTC] _currentRoot='/usr/local/lsws/Example/html'
[Fri 29 Apr 2022 06:36:08 PM UTC] entry='"type":"http-01","status":"pending","url":"https://acme-v02.api.letsencrypt.org/acme/chall-v3/103401127637/KbvqEw"," token":"K1_5aKesX2Snxr4HZCK4Lm2f22FYvBKeO-zbiyD4DHM"'
[Fri 29 Apr 2022 06:36:08 PM UTC] token='K1_5aKesX2Snxr4HZCK4Lm2f22FYvBKeO-zbiyD4DHM'
[Fri 29 Apr 2022 06:36:08 PM UTC] uri='https://acme-v02.api.letsencrypt.org/acme/chall-v3/103401127637/KbvqEw'
[Fri 29 Apr 2022 06:36:08 PM UTC] keyauthorization='K1_5aKesX2Snxr4HZCK4Lm2f22FYvBKeO-zbiyD4DHM.v4-VUckGPXP2MmGbvdqXScqIsPhtA7MdYBva0oqUvos'
[Fri 29 Apr 2022 06:36:08 PM UTC] dvlist='panel.chilevapo.cl#K1_5aKesX2Snxr4HZCK4Lm2f22FYvBKeO-zbiyD4DHM.v4-VUckGPXP2MmGbvdqXScqIsPhtA7MdYBva0oqUvos#https:// acme-v02.api.letsencrypt.org/acme/chall-v3/103401127637/KbvqEw#http-01#/usr/local/lsws/Example/html'
[Fri 29 Apr 2022 06:36:08 PM UTC] d='www.panel.chilevapo.cl'
[Fri 29 Apr 2022 06:36:08 PM UTC] Getting webroot for domain='www.panel.chilevapo.cl'
[Fri 29 Apr 2022 06:36:08 PM UTC] entry='"type":"http-01","status":"pending","url":"https://acme-v02.api.letsencrypt.org/acme/chall-v3/103401127647/4GlWRA"," token":"0zqT8zPwtUgtfiTMQEew58PjuSVKH9C-IKEgv5rkfqg"'
[Fri 29 Apr 2022 06:36:08 PM UTC] token='0zqT8zPwtUgtfiTMQEew58PjuSVKH9C-IKEgv5rkfqg'
[Fri 29 Apr 2022 06:36:08 PM UTC] uri='https://acme-v02.api.letsencrypt.org/acme/chall-v3/103401127647/4GlWRA'
[Fri 29 Apr 2022 06:36:08 PM UTC] keyauthorization='0zqT8zPwtUgtfiTMQEew58PjuSVKH9C-IKEgv5rkfqg.v4-VUckGPXP2MmGbvdqXScqIsPhtA7MdYBva0oqUvos'
[Fri 29 Apr 2022 06:36:08 PM UTC] dvlist='www.panel.chilevapo.cl#0zqT8zPwtUgtfiTMQEew58PjuSVKH9C-IKEgv5rkfqg.v4-VUckGPXP2MmGbvdqXScqIsPhtA7MdYBva0oqUvos#http s://acme-v02.api.letsencrypt.org/acme/chall-v3/103401127647/4GlWRA#http-01#/usr/local/lsws/Example/html'
[Fri 29 Apr 2022 06:36:08 PM UTC] vlist='panel.chilevapo.cl#K1_5aKesX2Snxr4HZCK4Lm2f22FYvBKeO-zbiyD4DHM.v4-VUckGPXP2MmGbvdqXScqIsPhtA7MdYBva0oqUvos#https://a cme-v02.api.letsencrypt.org/acme/chall-v3/103401127637/KbvqEw#http-01#/usr/local/lsws/Example/html,www.panel.chilevapo.cl#0zqT8zPwtUgtfiTMQEew58PjuSVKH9C-IKE gv5rkfqg.v4-VUckGPXP2MmGbvdqXScqIsPhtA7MdYBva0oqUvos#https://acme-v02.api.letsencrypt.org/acme/chall-v3/103401127647/4GlWRA#http-01#/usr/local/lsws/Example/h tml,'
[Fri 29 Apr 2022 06:36:08 PM UTC] ok, let's start to verify
[Fri 29 Apr 2022 06:36:08 PM UTC] Verifying: panel.chilevapo.cl
[Fri 29 Apr 2022 06:36:08 PM UTC] wellknown_path='/usr/local/lsws/Example/html/.well-known/acme-challenge'
[Fri 29 Apr 2022 06:36:08 PM UTC] writing token:K1_5aKesX2Snxr4HZCK4Lm2f22FYvBKeO-zbiyD4DHM to /usr/local/lsws/Example/html/.well-known/acme-challenge/K1_5aK esX2Snxr4HZCK4Lm2f22FYvBKeO-zbiyD4DHM
[Fri 29 Apr 2022 06:36:08 PM UTC] Changing owner/group of .well-known to root:root
[Fri 29 Apr 2022 06:36:08 PM UTC] url='https://acme-v02.api.letsencrypt.org/acme/chall-v3/103401127637/KbvqEw'
[Fri 29 Apr 2022 06:36:08 PM UTC] payload='{}'
[Fri 29 Apr 2022 06:36:08 PM UTC] POST
[Fri 29 Apr 2022 06:36:08 PM UTC] _post_url='https://acme-v02.api.letsencrypt.org/acme/chall-v3/103401127637/KbvqEw'
[Fri 29 Apr 2022 06:36:08 PM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header -L -g '
[Fri 29 Apr 2022 06:36:08 PM UTC] _ret='0'
[Fri 29 Apr 2022 06:36:08 PM UTC] code='200'
[Fri 29 Apr 2022 06:36:08 PM UTC] trigger validation code: 200
[Fri 29 Apr 2022 06:36:08 PM UTC] Pending, The CA is processing your order, please just wait. (1/30)
[Fri 29 Apr 2022 06:36:08 PM UTC] sleep 2 secs to verify again
[Fri 29 Apr 2022 06:36:10 PM UTC] checking
[Fri 29 Apr 2022 06:36:10 PM UTC] url='https://acme-v02.api.letsencrypt.org/acme/chall-v3/103401127637/KbvqEw'
[Fri 29 Apr 2022 06:36:10 PM UTC] payload
[Fri 29 Apr 2022 06:36:10 PM UTC] POST
[Fri 29 Apr 2022 06:36:10 PM UTC] _post_url='https://acme-v02.api.letsencrypt.org/acme/chall-v3/103401127637/KbvqEw'
[Fri 29 Apr 2022 06:36:10 PM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header -L -g '
[Fri 29 Apr 2022 06:36:10 PM UTC] _ret='0'
[Fri 29 Apr 2022 06:36:10 PM UTC] code='200'
[Fri 29 Apr 2022 06:36:10 PM UTC] panel.chilevapo.cl:Verify error:144.202.46.114: Invalid response from http://panel.chilevapo.cl/.well-known/acme-challenge/K1_5aKesX2Snxr4HZCK4Lm2f22FYvBKeO-zbiyD4DHM: 404
[Fri 29 Apr 2022 06:36:10 PM UTC] Debug: get token url.
[Fri 29 Apr 2022 06:36:10 PM UTC] GET
[Fri 29 Apr 2022 06:36:10 PM UTC] url='http://panel.chilevapo.cl/.well-known/acme-challenge/K1_5aKesX2Snxr4HZCK4Lm2f22FYvBKeO-zbiyD4DHM'
[Fri 29 Apr 2022 06:36:10 PM UTC] timeout=1
[Fri 29 Apr 2022 06:36:10 PM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header -L -g --connect-timeout 1'
<!DOCTYPE html>
<html style="height:100%">
<head>
<meta name="viewport" content="width=device-width, initial-scale=1, shrink-to-fit=no" />
<title> 404 Not Found
</title></head>
<body style="color: #444; margin:0;font: normal 14px/20px Arial, Helvetica, sans-serif; height:100%; background-color: #fff;">
<div style="height:auto; min-height:100%; "> <div style="text-align: center; width:800px; margin-left: -400px; position:absolute; top: 30%; left:50%;">
<h1 style="margin:0; font-size:150px; line-height:150px; font-weight:bold;">404</h1>
<h2 style="margin-top:20px;font-size: 30px;">Not Found
</h2>
<p>The resource requested could not be found on this server!</p>
</div></div><div style="color:#f0f0f0; font-size:12px;margin:auto;padding:0px 30px 0px 30px;position:relative;clear:both;height:100px;margin-top:-101px;backg round-color:#474747;border-top: 1px solid rgba(0,0,0,0.15);box-shadow: 0 1px 0 rgba(255, 255, 255, 0.3) inset;">
<br>Proudly powered by <a style="color:#fff;" href="http://www.litespeedtech.com/error-page">LiteSpeed Web Server</a><p>Please be advised that LiteSpeed Tec hnologies Inc. is not a web hosting company and, as such, has no control over content found on this site.</p></div></body></html>
[Fri 29 Apr 2022 06:36:10 PM UTC] ret='0'
[Fri 29 Apr 2022 06:36:10 PM UTC] Debugging, skip removing: /usr/local/lsws/Example/html/.well-known/acme-challenge/K1_5aKesX2Snxr4HZCK4Lm2f22FYvBKeO-zbiyD4D HM
[Fri 29 Apr 2022 06:36:10 PM UTC] pid
[Fri 29 Apr 2022 06:36:10 PM UTC] No need to restore nginx, skip.
[Fri 29 Apr 2022 06:36:10 PM UTC] _clearupdns
[Fri 29 Apr 2022 06:36:10 PM UTC] dns_entries
[Fri 29 Apr 2022 06:36:10 PM UTC] skip dns.
[Fri 29 Apr 2022 06:36:10 PM UTC] _on_issue_err
[Fri 29 Apr 2022 06:36:10 PM UTC] Please check log file for more details: /root/.acme.sh/acme.sh.log
[Fri 29 Apr 2022 06:36:10 PM UTC] payload='{}'
[Fri 29 Apr 2022 06:36:11 PM UTC] _ret='0'
[Fri 29 Apr 2022 06:36:11 PM UTC] code='400'
[Fri 29 Apr 2022 06:36:11 PM UTC] url='https://acme-v02.api.letsencrypt.org/acme/chall-v3/103401127647/4GlWRA'
[Fri 29 Apr 2022 06:36:11 PM UTC] payload='{}'
[Fri 29 Apr 2022 06:36:11 PM UTC] POST
[Fri 29 Apr 2022 06:36:11 PM UTC] _post_url='https://acme-v02.api.letsencrypt.org/acme/chall-v3/103401127647/4GlWRA'
[Fri 29 Apr 2022 06:36:11 PM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header -L -g '
[Fri 29 Apr 2022 06:36:11 PM UTC] code='200'
[Fri 29 Apr 2022 06:36:11 PM UTC] Diagnosis versions:
openssl:openssl
OpenSSL 1.1.1f 31 Mar 2020
apache:
apache doesn't exist.
nginx:
nginx doesn't exist.
socat:
socat by Gerhard Rieger and contributors - see www.dest-unreach.org
socat version 1.7.3.3 on Oct 26 2019 17:42:04
running on Linux version #123-Ubuntu SMP Fri Apr 8 09:10:54 UTC 2022, release 5.4.0-109-generic, machine x86_64
features:
#define WITH_STDIO 1
#define WITH_FDNUM 1
#define WITH_FILE 1
#define WITH_CREAT 1
#define WITH_GOPEN 1
#define WITH_TERMIOS 1
#define WITH_PIPE 1
#define WITH_UNIX 1
#define WITH_ABSTRACT_UNIXSOCKET 1
#define WITH_IP4 1
#define WITH_IP6 1
#define WITH_RAWIP 1
#define WITH_GENERICSOCKET 1
#define WITH_INTERFACE 1
#define WITH_TCP 1
#define WITH_UDP 1
#define WITH_SCTP 1
#define WITH_LISTEN 1
#define WITH_SOCKS4 1
#define WITH_SOCKS4A 1
#define WITH_PROXY 1
#define WITH_SYSTEM 1
#define WITH_EXEC 1
#undef WITH_READLINE
#define WITH_TUN 1
#define WITH_PTY 1
#define WITH_OPENSSL 1
#undef WITH_FIPS
#define WITH_LIBWRAP 1
#define WITH_SYCLS 1
#define WITH_FILAN 1
#define WITH_RETRY 1
#define WITH_MSGLEVEL 0 /*debug*/
panel.chilevapo.cl:Verify error:144.202.46.114: Invalid response from http://panel.chilevapo.cl/.well-known/acme-challenge/ZqwLBM-XI5hn7D15nRVl_Uh5WCKFivPZTlUSTVqmkbs: 404
What can be causing this problem @die2mrw007
