SSL certification cannot issue after the first 90 days are past
I cannot issue SSL certification
Can you help me please
[01.27.2023_15-26-41] /root/.acme.sh/acme.sh --issue -d souqsquare.com -d www.souqsquare.com --cert-file /etc/letsencrypt/live/souqsquare.com/cert.pem --key-file /etc/letsencrypt/live/souqsquare.com/privkey.pem --fullchain-file /etc/letsencrypt/live/souqsquare.com/fullchain.pem -w /usr/local/lsws/Example/html -k ec-256 --force --server letsencrypt
[01.27.2023_15-26-48] Failed to obtain SSL for: souqsquare.com and: www.souqsquare.com
[01.27.2023_15-26-48] Trying to obtain SSL for: souqsquare.com
[01.27.2023_15-26-54] Failed to obtain SSL, issuing self-signed SSL for: souqsquare.com
[01.27.2023_15-26-55] Connection unexpectedly closed
[01.27.2023_15-26-56] Self signed SSL issued for souqsquare.com.
[01.27.2023_15-36-42] Status Code: 404 for: http://www.souqsquare.com/.well-known/acme-challenge/souqsquare.com. Error:
404 Not Found
404 Not Found
openresty
[01.27.2023_15-36-42] Status Code: 404 for: http://souqsquare.com/.well-known/acme-challenge/souqsquare.com. Error:
404 Not Found
404 Not Found
openresty
[01.27.2023_15-36-46] /root/.acme.sh/acme.sh --issue -d souqsquare.com -d www.souqsquare.com --cert-file /etc/letsencrypt/live/souqsquare.com/cert.pem --key-file /etc/letsencrypt/live/souqsquare.com/privkey.pem --fullchain-file /etc/letsencrypt/live/souqsquare.com/fullchain.pem -w /usr/local/lsws/Example/html -k ec-256 --force --server letsencrypt
[01.27.2023_15-37-03] Failed to obtain SSL for: souqsquare.com and: www.souqsquare.com
[01.27.2023_15-37-03] Trying to obtain SSL for: souqsquare.com
[01.27.2023_15-37-10] Failed to obtain SSL, issuing self-signed SSL for: souqsquare.com
[01.27.2023_15-37-11] Connection unexpectedly closed
[01.27.2023_15-37-11] Self signed SSL issued for souqsquare.com.
[01.27.2023_15-43-51] Status Code: 404 for: http://www.souqsquare.com/.well-known/acme-challenge/souqsquare.com. Error:
404 Not Found
404 Not Found
openresty
[01.27.2023_15-43-51] Status Code: 404 for: http://souqsquare.com/.well-known/acme-challenge/souqsquare.com. Error:
404 Not Found
404 Not Found
openresty
[01.27.2023_15-43-56] /root/.acme.sh/acme.sh --issue -d souqsquare.com -d www.souqsquare.com --cert-file /etc/letsencrypt/live/souqsquare.com/cert.pem --key-file /etc/letsencrypt/live/souqsquare.com/privkey.pem --fullchain-file /etc/letsencrypt/live/souqsquare.com/fullchain.pem -w /usr/local/lsws/Example/html -k ec-256 --force --server letsencrypt
[01.27.2023_15-44-03] Failed to obtain SSL for: souqsquare.com and: www.souqsquare.com
[01.27.2023_15-44-03] Trying to obtain SSL for: souqsquare.com
[01.27.2023_15-44-11] Failed to obtain SSL, issuing self-signed SSL for: souqsquare.com
[01.27.2023_15-44-12] Connection unexpectedly closed
[01.27.2023_15-44-12] Self signed SSL issued for souqsquare.com.
Are you using cloudflare? If so disable proxy and try again.
I am using hostinger
