no success
@si668p What error have you gotten
the same as before
Sad to hear that
Repeat this process SSL certificate error - #20 by josephgodwinke
DO NOT reissue the ssl.
First upgrade CyberPanel, Run wget -O - https://get.acme.sh | sh then setup detailed debug logs and reboot.
Resissue SSL by running cyberpanel issueSSL --domainName obrtnik.net as you tail /home/cyberpanel/error-logs.txt or debug using commandline
[11.03.2022_18-15-35] /root/.acme.sh/acme.sh --issue -d obrtnik.net -d www.obrtnik.net --cert-file /etc/letsencrypt/live/obrtnik.net/cert.pem --key-file /etc/letsencrypt/live/obrtnik.net/privkey.pem --fullchain-file /etc/letsencrypt/live/obrtnik.net/fullchain.pem -w /usr/local/lsws/Example/html -k ec-256 --force --server letsencrypt
[11.03.2022_18-15-35] Failed to obtain SSL for: obrtnik.net and: www.obrtnik.net
[11.03.2022_18-15-35] Trying to obtain SSL for: obrtnik.net
[11.03.2022_18-15-43] Failed to obtain SSL, issuing self-signed SSL for: obrtnik.net
[11.03.2022_18-15-43] Self signed SSL issued for obrtnik.net.
2022-11-03 19:19:26.167978 [INFO] [60528] [Module:mod_security] setSecRule value: /usr/local/lsws/conf/modsec/rules.conf, type: 2
2022-11-03 19:19:26.168639 [INFO] [60528] [Module: modcompress 1.1] has been initialized successfully
2022-11-03 19:19:26.168768 [INFO] [60528] [Module: moddecompress 1.1] has been initialized successfully
2022-11-03 19:19:26.169087 [INFO] [60528] [Module: cache 1.64] has been initialized successfully
2022-11-03 19:19:26.169253 [INFO] [60528] [Module: mod_security mod_security 1.4] has been initialized successfully
2022-11-03 19:19:26.169311 [ERROR] [60528] Path for certificate file is invalid: /usr/local/lsws/admin/conf/webadmin.crt
2022-11-03 19:19:26.169336 [ERROR] [60528] [config:admin:listener] No listener is available for admin virtual host!
2022-11-03 19:19:26.169750 [ERROR] [60528] Fatal error in configuration, exit!
Please remove obrtnik.net domain ssl certificates completely from your server SSL certificate error - #20 by josephgodwinke
After removing obrtnik.net domain ssl certificates completely from your server and reissuing via cyberpanel fails:
$ /root/.acme.sh/acme.sh --issue -d obrtnik.net --cert-file /etc/letsencrypt/live/obrtnik.net/cert.pem --key-file /etc/letsencrypt/live/obrtnik.net/privkey.pem --fullchain-file /etc/letsencrypt/live/obrtnik.net/fullchain.pem -w /usr/local/lsws/Example/html --force --debug
- Create file anything.txt in /usr/local/Example/html/.well-known/acme-challenge/ and try to access it via yourdomain.com is available for purchase - Sedo.com
- If point 1 is working then run SSL command otherwise verify the vhost config context for the .well-known if not there create it or ask for context code
Note: the SSL verify file will not open in browser if site is using openlitespeed as proxy to other webserver with / path.
Try and let me know result ![]()
For the error NET:ERR_CERT_AUTHORITY_INVALID in web browsers indicates a problem with the website’s SSL certificate, meaning the browser can’t verify its authenticity. This typically suggests an issue with the certificate authority (CA), the expired certificate, or a mismatch between the domain and certificate. You shouldn’t get this issue unless you haven’t installed a certificate or are utilizing HTTP, which isn’t recommended for your website. There are many different ways to fix the error, which you need to understand in details.
I hope it helps!
