evrything installed success except them:
updates | 3.4 kB 00:00:00
(1/7): base/7/x86_64/group_gz | 166 kB 00:00:00
(2/7): extras/7/x86_64/primary_db | 180 kB 00:00:00
(3/7): base/7/x86_64/primary_db | 6.0 MB 00:00:00
epel/x86_64/updateinfo FAILED
http://mirrors.kernel.org/fedora-epel/7/x86_64/repodata/d649589f99ee125179eebedc0cdd05f49d7f5723032bff040a4cd05701703e8d-updateinfo.xml.bz2: [Errno 14] HTTP Error 404 - Not Found
Trying other mirror.
To address this issue please refer to the below wiki article
https://wiki.centos.org/yum-errors
If above article doesn’t help to resolve this issue please use https://bugs.centos.org/.
(4/7): epel/x86_64/group_gz | 88 kB 00:00:00
http://mirrors.develooper.com/epel/7/x86_64/repodata/d649589f99ee125179eebedc0cdd05f49d7f5723032bff040a4cd05701703e8d-updateinfo.xml.bz2: [Errno 14] HTTP Error 404 - Not Found
epel/x86_64/primary_db FAILED
https://mirror.chpc.utah.edu/pub/epel/7/x86_64/repodata/b1c3f0f5e9615c17889c7d93f5e2fbe5bc853c6aa13240ab713a3654f2374fa8-primary.sqlite.bz2: [Errno 14] HTTPS Error 404 - Not Found
(5/7): epel/x86_64/updateinfo | 962 kB 00:00:00
(6/7): updates/7/x86_64/primary_db | 2.4 MB 00:00:00
(7/7): epel/x86_64/primary_db | 6.6 MB 00:00:00
No packages marked for update
[11-41-54-Tue-Feb-2019] #########################################################################
[11-41-54-Tue-Feb-2019] Install GUnicorn
Searching for gunicorn
Reading Links for gunicorn
Best match: gunicorn 19.9.0
Downloading https://files.pythonhosted.org/packages/47/52/68ba8e5e8ba251e54006a49441f7ccabca83b6bef5aed acb4890596c7911/gunicorn-19.9.0.tar.gz#sha256=fa2662097c66f920f53f70621c6c58ca4a3c4d3434205e608e121b5b3 b71f4f3
Processing gunicorn-19.9.0.tar.gz
Writing /tmp/easy_install-CHhafB/gunicorn-19.9.0/setup.cfg
Running gunicorn-19.9.0/setup.py -q bdist_egg --dist-dir /tmp/easy_install-CHhafB/gunicorn-19.9.0/egg-d ist-tmp-oP6Aqk
/usr/lib64/python2.7/distutils/dist.py:267: UserWarning: Unknown distribution option: ‘python_requires’
warnings.warn(msg)
warning: no previously-included files matching ‘pycache’ found under directory ‘’
warning: no previously-included files matching '.py[co]’ found under directory ‘*’
File “build/bdist.linux-x86_64/egg/gunicorn/workers/_gaiohttp.py”, line 84
yield from self.wsgi.close()
SyntaxError: invalid syntax
File “/usr/lib/python2.7/site-packages/gunicorn-19.9.0-py2.7.egg/gunicorn/workers/_gaiohttp.py”, line 84
Adding gunicorn 19.9.0 to easy-install.pth file
Installing gunicorn script to /usr/bin
Installing gunicorn_paster script to /usr/bin
Installed /usr/lib/python2.7/site-packages/gunicorn-19.9.0-py2.7.egg
Processing dependencies for gunicorn
Finished processing dependencies for gunicorn
chown: invalid user: ‘mysql’
[11-45-24-Tue-Feb-2019] #########################################################################
[11-45-24-Tue-Feb-2019] Succcessfully installed rsync!
chown: invalid user: ‘lscpd:lscpd’
[11-45-24-Tue-Feb-2019] Trying to change owner for /usr/local/lscp/cyberpanel/, trying again, try number: 1
[11-45-24-Tue-Feb-2019] Trying to change owner for /usr/local/lscp/cyberpanel/, trying again, try number: 2
[11-46-02-Tue-Feb-2019] #########################################################################
[11-46-02-Tue-Feb-2019] Trying to setup LSCPD Daemon!
File “install.py”, line 3319, in
main()
File “install.py”, line 3273, in main
checks.setupLSCPDDaemon()
File “install.py”, line 2208, in setupLSCPDDaemon
shutil.copy(“lscpd/lscpdctrl”, “/usr/local/lscp/bin/lscpdctrl”)
File “/usr/lib64/python2.7/shutil.py”, line 119, in copy
copyfile(src, dst)
File “/usr/lib64/python2.7/shutil.py”, line 83, in copyfile
with open(dst, ‘wb’) as fdst:
IOError: [Errno 2] No such file or directory: ‘/usr/local/lscp/bin/lscpdctrl’
Something went wrong…
