After uploading a file when I’m trying to Extract then it shows an error!!
ERROR: “Not allowed to move in this path, please choose location inside home!”
Any solution?..
please search at forum…
this is known issue and will be handled ASAP
I already searched and applied those solutions but not solving…!!
but i still facing the problem
and confirmation with developer
you can join there
the subject your post changed to solved because cyberpanel community already know this bug and developer are working on it
update: Update your Cyberpanel… this issue solved
After the update, the extract problem has been fixed now.
Thanks
