Rich
1
I can’t figure out how to set an environment variable that I can then access from PHP using getenv()
I want to set an API key in the environment so that it’s not hard coded in the app, and access it like this:
$api_key = getenv("API_KEY");
So far everything I’ve tried has failed to work.
Rich
2
OK, I figured it out:
Just set them in the vHost Conf file:
extprocessor blah1234 {
env API_KEY=secretkey
but the missing link is you must restart PHP otherwise that key won’t be visible with getenv():
killall -9 lsphp
system
Closed
3
