I want to remove the panel for some reasons.
How can I remove it?
By re-installing the OS.
It should be on the installation docs.
HOW DELETE THIS BUGGY PANEL??? Can´t reinstall OS yet.
When doing anything with data, backup, backup, backup… 3 most important things. I am assuming @MrZee this came from your post about slow performance on a min spec environment? before resorting to drastic measures of reinstalling the OS, maybe try going to 2GB or 4GB, I use 4GB for the VM I use and although still testing it screams… sub 300ms for web sites to load according to tools.pingdom.com although it is up to you what you do, but having a plan B or a backup is always the best solution so you do not need to act in haste.
