Has anyone else had this issue and found a solution?
I can change the PHP files, but it does not change on the phpinfo(); check at all.
It stays at 2M.
Also mentioned here:
Uploaded file in php.ini - Support and Discussion / FTP Server - CyberPanel Community
SOLUTION:
Check if Apache or it uses normal OpenLiteSpeed PHP configs.
Mine used Apache.
