Hi all
I just created new server on DigitalOcean using Almalinux 8.
I want instal CyberPanel. but it stopped. the errors:
I tried using Ubuntu too but the same. I think DigitalOcean Agent cause this.
So for time being, I can not install CyberPanel.
Thank you
Update.
I follow this article:
How to Remove the DigitalOcean Metrics Agent Package or Repository from Droplets
Step 1: Remove the Metrics Agent
sudo yum remove do-agent
Step 2: Remove the Metrics Agent Repository
sudo rm /etc/yum.repos.d/digitalocean-agent.repo
Step 3: Instal CyberPanel as usual. Worked successfully.
