SOLUTION: Wrong admin password for rainloop in cyberpanel
Okay, I have been battling for days trying to login to rainloop admin. I keep getting wrong authentication.
I had installed cyberpanel on ubuntu and the password provided for rainloop admin was not working.
I have managed to find solution and I thought I should share for future reference. So the main issue is that the password provided was not correct, to find the correct password do the following.
  1. Go to terminal and connect as root
  2. Go to this path using cd command (/usr/local/CyberCP/public/)
  3. Then write ls to see the list of fills and/or folder. One of the files you will see is rainloop.php
  4. Write view rainloop.php to view the file. The correct password will be in there on plain text.
  5. That’s it. You can click ctrl + z to exit the view file.
Enjoy
