I updated CP to the latest version.
Change Logs says “Replace Rainloop with SnappyMail”
Should it be working already?
In my panel in the webmail tab a blank page opens without any errors … xxx.example.com/snappymail/index.php.
If I manually change to xxx.example.com/rainloop, the rainloop opens as before and everything works as usual.
today I get 500 Internal Server Error as I try to run snappymail …
The problem was the recaptcha plug set in the rainloop. When disabled, snappymail starts and you can login
Now I have a problem logging into admin.
I checked:
- login and password rainloop - does not work
- login and password snappymail.php - does not work
- login and password /usr/local/lscp/cyberpanel/rainloop/data/data/default/application.ini - does not work
I was able to log in.
/usr/local/lscp/cyberpanel/rainloop/data/_data_/_default_/configs/application.inicomment out the admin_password line (;admin_password =) - generate a new password by trying to log in as admin (
https://cp.example.com/snappymail/?admin) - log in using the new password from
/usr/local/lscp/cyberpanel/rainloop/data/_data_/_default_/admin_password.txt - change the password in the panel after logging in
