One of the major things i faced installing new server with control panel is adjusting the SMTP banner to meet the requirements of not spamming my emails…
So is this feature available in cyberpanel?
What is banner smtp?
SMTP banner is the server name sending helo message …
i found the solution in postfix… u can edit the server.example.com to your site name so u dont have smtp banner mismatch…
thanks
Can you please elaborate on the file that needs to be edited and the location?
SMTP banner is the server name sending helo message ..
i found the solution in postfix... u can edit the server.example.com to your site name so u dont have smtp banner mismatch..
thanks
Where is the file located?
Can someone post the location of postfix config file?
they are in /etc/postfix
