Provider: netcup
System: Ubuntu 18.04
OLS or Enterprise?
OLS
official
no
no
Install LiteSpeed Memcached?
no
Install Memcached?
no
no
Install Redis?
no
Problem:
When I login to do OLS Panel on a fresh install of Cyberpanel, there is a error error message:
2019-01-16 12:59:26.168728 ERROR [config:server:vhosts:vhost:Example:context:/protected/] Path for context location is invalid: /usr/local/lsws/Example/html/protected/
No biggie but this can be probably easily solved at the install script.
Also i suggest to already include another rule within the Cyberpanel Security Settings:
OLS Panel tcp 0.0.0.0/0 7080
This saves new users who want to use a firewall from searching on where to enable the needed Port 7080 for OLS Panel
Rock on! Best regards and Thank you very much for the work on this Panel
Thomas
