Website is super super super slow… (+1 min to load page >>> inspect >> network) but disable Litespeed plugin the website work normal speed…
Please help
Please help
Hello @lmilani Happy you are here
You need to tweak the plugin settings to fine tune your caching. If it ia big site I recommend a proper CDN some CDNs break caching functionalities of wp plugins like quic-cloud queue issues and use edge side includes (this requires LiteSpeed Web ADC - Load Balancer - LiteSpeed Technologies )
You also need to check plugin conflicts especially langauge switchers, other caching plugins.
As a start go to LiteSpeed Cache → Toolbox → Debug Settings and set Disable All Features to ON
Good afternoon, it is strange because I have 4 vps in Contabo that use CyberPanel and only in 1 of them do I have this generalized problem of Litespeed leaving all the sites where it is installed super slow. the problem is only overcome when I disable the wordpress plugin (litespeed).
Any more suggestions?
Have you checked this tutorial to see if you configured it correctly How to optimize WordPress site using LSCache Plugin - CyberHosting
If all servers are setup the same and have same resources then it seems you have an issue with a problematic JS or CSS file. Try the by excluding these js/css files for homepage and test page speed before and after
On this page you can get information regarding your LiteSpeed processes.
module versions:
lsquic 3.1.1
modgzip 1.1
cache 1.64
mod_security 1.4
Have you tried the following
htop and monitor server load when you visit any page on the website. If you have post a screenshot so that we can see server load.
