hello, i understand we can edit php.ini from vhost - phpIniOverride
but how if cyberpanel have direct edit php.ini file only ? actually i little tired to explain and answer to my customer about how to edit php.ini
Under PHP menu option from left panel, you can select “edit php configs” and there you can select the relevant php version and change its php.ini settings.
user access doesnt have php config… and if i do that in “admin” all php config will applied to all user
I’m also having a similar problem. I’m uploading a zip file and I’m getting this error “The uploaded file exceeds the upload_max_filesize directive in php.ini.”
I’ve already updated all PHP versions to 128M and with no result, do I still need to do anything else to change that?
same problem here
I tested via terminal too but had no success.
The way is to open a topic with the same subject until someone can solve it!
