CyberPanel Community
Shell_exec returns permissions error
Ah
Ahmed #1
Trying to copy files from /home/core_files to website folder, but permissions error returns
any idea how to fix it?
function copyStoreFiles($domain) {
    $cp = shell_exec('cp -r /home/core_files/* /home/'.$domain.'/public_html');
   // updateConfigValues();
jo
josephgodwinke #2
Welcome @chillyplate Happy you are here
You need to run your command as root/sudo user e.g.
shell_exec('sudo cp -r /home/core_files/* /home/'.$domain.'/public_html');
Let me know if this works
Ah
Ahmed #3
Thanks for the suggestion, but I tried running the command as sudo as you suggested, but unfortunately, it still isn’t working.
jo
josephgodwinke #4
Then you have to allow www-data to not use password by editing the sudoers file sudo visudo but this is not best practice
Ah
Ahmed #5
I’ve fixed it by getting the Linux user
shell_exec('whoami');
then copy the user and add it to the sudoers list
