Seems something wrong with upgrade
[2025-08-10 02:46:38] Installing lswsgi binary…
[2025-08-10 02:46:38] Running final verification…
[2025-08-10 02:46:38] All components successfully installed!
[2025-08-10 02:46:38] Main_Upgrade function completed
sed: can’t read /usr/local/CyberCP/serverStatus/serverStatusUtil.py: No such file or directory
i am stuck at update how i can fix it?
same issue. others file deleted from here
just updated 2 servers wothout any issue may i know your os
0 28124 0 0 0 0 0 0 --:–:-- --:–:-- --:–:-- 0
CyberPanel Upgraded
[root@31vef37t ~]#
Almalinux 9
on almalinux update working fine please open a ticket at support i will check
Exactly the same issue on Ubuntu 22.04.
Has anyone found a solution?
Should be fixed in v2.5.5-dev
usmannasir/cyberpanel at v2.5.5-dev
